I've built a pretty standard LED strobe with the 555 IC using **broken link removed**. I'm using these resistors/caps:
R1 - 1k
R2 - 1k + 1M pot
C - 0.1uF
V = 9V battery
It works as it should and I'm pretty pleased with the results (I'm a electronics neophyte). I'd like to adjust the circuit so that the high signal is always ~ 0.01 seconds. According to the schematics in the link I can place a 1N4148 diode across the 7 and 6 pins of the 555. When I do this, however, the LED remains on and never flashes. I've tried different resistors/caps for R1 and C but the result is always the same.
Does anybody have a hint at what I might be doing wrong? I'm sure it's difficult without seeing my circuit but I'm hoping there's some common problem known to veterans.
R1 - 1k
R2 - 1k + 1M pot
C - 0.1uF
V = 9V battery
