Need 5 to 0 to 5 volt ref
kinarfi
Here's what I have come up with so far and was wondering if there was a better way to covert a 0 to 10 signal to 5 to 0 to 5 signal, < 30 Hz. The absolute value circuit actually worked on a bread board, but not in Spice.
This is a 12V to 0V >> 0 to 5V I did recently.
  • Lev12to0a.asc
    Lev12to0a.asc
Thanks, modified your .asc a bit Untitle2 yellow trace is about right for what I want. Just need the right zeners.
Thanks Again,
Kinarfi
  • Absolute Value.asc
    Absolute Value.asc
Here's my final and it worked perfectly
If your posted circuit is correctly drawn, it does not work.?
For example the +5Vref OPA outputs 0V.
The main output on U5 pin #1 just follows whats input on Vin.
Have you posted the wrong circuit.?
EDIT:
The error in your drawing is the +5Vref circuit.
I'm a bit confused here.
So you need to convert 0V to 10V to 5 - 0 - 5V?
What does that mean exactly?
I assume that input of 5V needs to output 0V but what should the output be with an input of 0V? -5V?
I've read all the posts and looked at the graphs but it still isn't clear to me.
EDIT:
I've had another look at the schematic and graph posted by Eric and it seems clear now.
Vout = absolute(Vin-5)
Seems like an unusual thing to do.
Perhaps there's a simpler way.
EDIT:
I think what he is after is making the +5V point of the 0V to +10V input signal his 0V output reference voltage, also he wants to output the absolute values of the 0V to +10V input.
So he will get +5V thru 0V thru +5V, for a 0 to +10V input.
Why, I can only guess.
Some answers and reasons, I have a strain gauge feeding an instrument amplifier and the output was from about 2 to 12 with a 14.4 supply and a 50% reference, power is from the alternator of a vehicle and drops to about 12 when the engine is off, so I basically have an unstable power supply to contend with. I am using an LM317 to provide a stable 10 v and need a 0 - 5 to control the out put of another controller, so I'm using a 5.00 ref for the strain gauge amp and another 5.000 ref for voltage manipulation to achieve an absolute 10 - 5 - 10 then subtract 5 for my 5 - 0 - 5 to feed the controller and flipping an h bridge with the out to NFETs which feeds PFETs with a small dead band.
Eric was correct about having some incorrect wiring, I replace spices 5 v supply with the voltage divider as I developed the schematic and didn't run/check it. I have corrected it and included it, hope this clears up some questions about why I wanted this. If you have any suggestions, I'm listening.
Thank for the help,
Kinarfi
A tad more info, on the graph, 1.0 seconds in neutral / no input. as you push or pull, left or right, Vin goes up or down.
tnx
kinarfi
That looks pretty complicated.
Is it not possible to reconfigure the controller and do it in software?
All those op-amps are just going to introduce more errors into the reading.
Actually, It's working very good. As I put 0 - 10 into it I get a very good +5 to 0 to +5 out. It's 10 to 5 to 10 after the absolute value, 5 to 0 to 5 after the "subtraction". Presently waiting for the interface to controller. It's supposed to take 0 to 5, but it's only taking 1 to 1.7 as is. Hopefully it can be reprogrammed.
It is just 2 quad op-amps and an instrument amp chip + resistrors & diodes.
Kinarfi
Kinarfi
Ran your asc file in LTspice, OK.
Is that overlap on the N FET drive output going to be aproblem.?
Kinarfi
Have you actually built it yet or have you just simulated it?
Don't expect the real thing to work as well as the simulator says it will.
Hero, Yes, built it, ran it, tested it with DVM, Probably ought to put a scope on to see if I'm getting any of the oscillations your rightfully worried about. But it does seem to be doing exactly as spice shows it.
Eric, You caught me again, swap the input on U7 & U8 and you get separation instead of over lap. I will say I did draw it correctly on my schematic and as I built it, just not in spice.
Thanks,
kinarfi
