Multi sla agm charger
Stuee123
Hi. I have 8 barrels with a hgl45-12 and led lights on the.
The batteries are under the top and I have put a dc socket on the side of the barrel to charge.
I use a regular car battery charger. But doing one at a time is annoying.
Is there a way I can charge them all at once. They only get charged once a week.
Not sure if I can use an esp32 or rpi as the monitor and charge controller?
Thanks in advance.
Do not use an automotive battery charger for small SLA batteries, as they are designed for excess voltage. >=14.2 rather than 13.7V
  • Leaving a battery discharged for a long time can lead to sulfation, which can damage the battery (like overnight every day).
  • Use a low voltage cutoff circuit and never go below 30% SoC.
  • Make sure to remove the battery charger after it is fully charged
1749596190832-png.150133
Any questions?
The hgl45-12 is a 45AH AGM, not SLA.
The data sheet voltage for cyclic charging is 14.5 - 14.9, with a maximum current of 5.6A (though the HGL series data sheet states 0.25C maximum, so 11A).
As the current drops off during charge, the on-charge time could be around ten hours or so if the battery has been discharged significantly, and the charger should be a two stage one that automatically switches to float charge once the bulk charge is completed.
It's not safe to connect batteries at different states of charge in parallel as the equalising currents could be very high! Also, parallel connection means the charger cannot detect full charge in any one battery, so the life expectancy will be significantly reduced.
The only safe way is to use a bank of separate AGM chargers rated at 6A or less, set for the correct voltage limit, and let each battery / charger reach full charge and switch to float charge in its own time.
Good "smart" chargers are not cheap, but well worth it in comparison to the cost of the batteries.
Do not use an old type "dumb" charger or single stage without charge state detection, as that will shorten the battery life.
