Mounting stripboard/veroboard?
antknee
What is the best way of mounting a strip/veroboard? I just want to use a nut and bolt to attach it to say some acrylic, so it is held firmly.
I think if I drill a hole through it I'll find it will crack. I do vaguely remember some kind of pins but I wouldn't know what to call them.
Thanks,
Antknee.
An interesting project!
I think I will drill the holes first and then solder the parts to the board and then mount using some pillars. Thanks both!
Those micro reamers do a nice job - they will definitly not crack the holes. Then again, a 3mm hole followed by a 4mm hole shouldn't either.
Andrew
I use epoxy-fiberglass Veroboard and stripboard. It doesn't stink, doesn't crack and doesn't warp like phenolic-paper cheap circuit board material.
I use both phenolic, and fiberglass boards. I drill them with a drill press and use either 4-40 or 6-32 threaded spacers, most are about 1/2" long. Sometimes I use M/F threaded spacers.
If I'm forced to drill a paper phenolic board, I get best results in a drill press:
- board clamped firmly (as near as possible to the hole),
- sharp drill,
- relatively high RPM,
- a very low feed rate.
For cleaner holes you could also put a piece of thin board over the top and bottom and clamp that as well, it prevents the 'blowout' mess that a drill tends to leave when it punches through and will help against chipping when you start the hole, the denser the board you use the better.
