Hello,
I have a LVDS display and a VIA EPIA NL5000EG board and would like to know if the two are compatible. I know I will need the LVDS card LVDS-07G for the main board, but it says it is for 18/24-bit LCD panel display selected by SKU. The display I have I thinks it's 6 bit interface which will make it 18 bits (is that correct?). Below are the two module models.
Would the 24-bit version of the LVDS-07G work with the display?
TIANMA LVDS DISPLAY TM104SBH01
Size 10.4 inch
Resolution 800(RGB) x 600
Interface LVDS 6 bits
Color Depth 262K
Technology Type a-Si
Pixel Pitch (mm) 0.264x0.264
Pixel Configuration R.G.B. Vertical Stripe
Display Mode TM with Normally White
Surface Treatment(Up Polarizer) Anti-Glare(3H)
Surface Treatment(TSP) Anti-glare type (3H)
Viewing Direction 12 o’clock
Display Spec.
Gray Scale Inversion Direction 6 o’clock
LCM (W x H x D) (mm) 236.00x176.90x7.3
Active Area(mm) 211.20x158.40
With /Without TSP With TSP
Mechanical
Characteristics
Weight (g) 412
VIA Nano ITX EPIA NL5000EG
Model Name VIA EPIA-NL5000EG
Processor VIA Luke CoreFusion 500MHz Processor
Chipset VIA VT8237R-Series South Bridge
System Memory 1 DDR266/333/400 SO-DIMM Slot
Up to 1GB memory size
VGA Integrated S3 Graphics UniChrome™ Pro AGP graphics with MPEG-2 Decoder/MPEG-4 Acceleration
Expansion Slots 1 Mini-PCI slot
Onboard IDE 2 UltraDMA 133/100/66 Connectors (Secondary 2.0mm 44-pin header)
Onboard Serial ATA 1 SATA Connector
Onboard LAN VIA VT6103L 10/100Mbps Base-T Ethernet PHY for broadband networking connectivity
Onboard Audio VIA Vinyl VT1617A Six-TRAC AC'97 Codec
Onboard TV Out VIA VT1625M HDTV Encoder
Onboard I/O Connectors 1 USB pin header for 8 additional USB 2.0 ports
1 pin header for COM Port, SIR and LPC
1 CIR pin header (Switchable for PS/2 KB/MS)
2 Fan connectors: CPU/Sys FAN
1 LVDS connector (an add-on card is required)
1 Nano-iTX power connector
1 Audio pin header for Line-out, Line-in, Mic-in, CD-in and S/PDIF out
1 TV Out pin header for S-Video, Composite, and Component (YPbPr/Scart/D-Terminal)
1 pin header for 10/100 Ethernet LAN support
1 pin header for CRT, VGA output, SMBUS, and CAP0
BIOS Award BIOS
4/8Mbit flash memory
System Monitoring & Management CPU Temperature monitoring
CPU voltage monitoring
Wake-on-LAN, Keyboard-Power-on, Timer-Power-on, Watch Dog Timer, FAN Control
System power management
AC power failure recovery
Operating Temperature 0°C up to 47°C ~50°C (by different product items)
Operating Humidity 0% ~ 95% (relative humidity; non-condensing)
Form Factor Nano-ITX (8 layers)
12 cm x 12 cm
Size 10.4 inch
Color Depth 262K
Display Spec.
Mechanical
Characteristics
Weight (g) 412
BIOS Award BIOS
12 cm x 12 cm
