StudentSA
Lets do this design... for your case.... lets assume Fmax = 300Hz based on (4000 RPM * 4 (four cut flywheel?))/60sec = 264 Rounded up to 300.
Your Vcc is your supply! Not the internal zener regulated voltage. Remember the collector emitter of your output transistor is driven by the supply.
Now...
Fmax = I2/(C1*Vcc)
Thus C1 < 50nF
Now... R1 >= V3Max /I3min (from datasheet)
You want 0 -5 V?
So R1 >= 5/140uA >= 35714
Thus R1 >35714
Now we solve
Vout = Vcc x Fin x C1 x R1
5 = 12 x 265 x C1 x R1
5/(12*265) = R1 x C1
R1 = 5/(12*265*c1)
If we assume standard cap values below 50nf ... 47nF, 33nF, 22nF and 10nf
If C1 = 47nF .... R1 = 33453 Not Applicable as R1 is too small
If C1 = 33nF .... R1 = 47646 Great using a 47k resistor should be good enough
if C1 = 22nF .... R1 = 71469 Good 68k resistor plus 10k trim pot allow good accuracy
if C1 = 10nF .... R1 = 157232 maybe bit too high
So I advise trying C1 = 33nF or 22nF and the appropriate resistor
Best of luck mate
Now...
Fmax = I2/(C1*Vcc)
Thus C1 < 50nF
You want 0 -5 V?
Thus R1 >35714
Now we solve
R1 = 5/(12*265*c1)
Best of luck mate
