For example, Ethernet networks typically use twisted pair cable and not Coaxial cable.
Copper coated steel wire reminds me of the time 50 years ago 1969 when the Railroad took down all the wires running parallel to the railroad tracks for a 100 miles. I got about 600 feet of that free wire to run 120 VAC from the house to my fathers barn. I ran 2 wire from the house 250 feet to the barn light bulbs light up a very dull orange color, they did not make enough light to see anything. Wire was worthless. I replaced the wire with copper Romex then light bulbs were bright and made lots of light. The steel wire was used to make fences. I expect copper coated steel coax wire is worthless too. I hate to put more trash in the land fill, maybe someone on market place will have a use for free wire.
You're just confusing yourself - it's NOT for doing mains wiring, it's for low level RF signals - so there's little current flow anyway, and due to skin effect (at the high frequencies used) the signal will be carried down the copper coating.
Likewise the railway wire - presumably it was low current signalling wire?, and not for mains distribution.
Will it work good of a TV antenna? People on the TV antenna forum said, NO.
It depends on it's specification - for a start, is it 75 ohm or 50 ohm?.Will it work good of a TV antenna? People on the TV antenna forum said, NO.
Cable TV in the US - almost certainly 75 ohm. That cable looks fatter than standard RG59- or RG6-ish cables, so probably a low-loss type.is it 75 ohm or 50 ohm?.
ak
ak
Remember it well. All was good until someone moved their computer and just disconnected the network cable or a dodgy connection somewhere. Reliability greatly increased with twisted pair and hubs.Coaxial cable used to be commonly used for networks, it used BNC plugs, and t-connectors at each PC, with 75 ohm terminating loads at either end.
We did the same in the office, people stayed late just to play Doom. It was the first time I'd seen someone panic on screen.Ah - the days of playing network Doom over coax with my daughter, on 386's using DOS (pre-Windows)![]()
How do you cut any cable shorter and it still fits?
Devils advocate.
You don't think you could have used those connectors on the wire you already had, to shorten them?
Fittings are too large for black coax and almost too small for white coax. Fitting screw on the black coax so easy fittings fall off easy. Fittings are hard to screw on the white color cable TV coax, it was a struggle to force the fitting on with plyers. Black coax has been around so long I don't remember where it came from.
