HP 1740A Oscilloscope sweep problem
reipoom
I thought I fixed the problem, but it's still doing it. There is a bad connector right by the water bottle. It's hard to get to and there's the rod running through the circuit board.
I've used "DeoxIT GOLD" and moved the connectors quite a bit.
alec_t
Most Helpful Member
Neither of my scopes has a built-in water bottle! What on earth is that for?
Have you checked the supply rails (especially the X-axis supply rail) are stable and ok? If the scope is more than a few years old be suspicious of any supply reservoir electrolytic capacitors; they may be leaky (electrically or chemically) and/or have intermittent internal shorts which could drop the supply voltage and hence restrict the sweep.
EE World Online Articles
Loading
