Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
I need my pic to output 3.3V, but I'm not able to use a couple of diods to lower the voltage, while the line is swithces between 3.3V and ground. btw: Fever componts the better.
Most of the solutions mentioned above have a tradeoff with speed. If you have slow speeds, a zener will work or even a voltage divider, but if you need high speed, you'll really need a level shifter. The 74HC4050 is cheap and dirty (and plenty fast) six in a single package if you need that many.
Mr. Nigel is right for an example if you need the pic to comunicate with 3.3v logic level devices i surelly recomend the Max IC, if it's for something more simple the zener could do the trick
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
