home automation through telephone
kautilya
hi there,
i am trying a project on home automation through a telephone. i am trying to design my own system for this. can u give me some ideas regarding this? any site i should refer? any journal papers i can refer?
what is the simulation software i should know for designing this system?
i will appreciate if u help me in this matter.
regards
kautilya
crutschow
Most Helpful Member
What exactly are you trying to control?
Edit: Do you need to do this from a remote telephone, i.e. does it have to answer a telephone ring?
Conceptually, you will need a telephone audio transformer to couple the dial tone signal from the telephone line, a DTMF decoder circuit to detect the dial tones, and some sort of logic (probably a microcontroller) to detect a particular code sequence and perform a task. (It is also possible to detect DTMF signals directly with a microcontroller such as AN257 - DTMF Detection Using PIC18 Microcontrollers - Application Notes - Details).
Don't know that you would need any simulation software for that, unless you are performing some complex tasks.
Sceadwian
Banned
Try using Google to search for this stuff, all the information is out there. Once you get the project started if you have trouble or need help that's what the forums are for. But you should do your own preliminary research first. It avoids people having to answer the same questions over and over again.
As far as sim software goes LTSpice is very powerful, and more importantly free =) It isn't easy for beginners to use, but very much worth the time to get used to it.
LTSpice can be downloaded here
Linear Technology - LTspice IV Downloads and Updates
And has a very good community support group here (the help files suck)
LTspice : LTspice/SwitcherCAD III
kannagi
pc based gps system
hi there,
i am trying a project on pc based gps system. i am trying to design my own system for this. can u give me some ideas regarding this? any site i should refer? any journal papers i can refer?
what is the simulation applications i should know for designing this system?
regards
kannagi
mneary
I think the original poster may have solved the problem, or moved on. It's been more than a year.
EE World Online Articles
Loading
