I've been planning to build some home automation gear, originally I had intended for each light switch to have its own independent module. Unfortunately the cost the power supply components is causing problems with that approach and I am now considering other options (like several "region controllers" each of which powers and controls a number of nodes).
Can anyone suggest:
1) A cost effective way (<$6) to convert ~250VAC to ~8VDC @100+mA while providing good isolation? Transformers tend to be fairly expensive and most switch mode are either expensive or won't take input that high.
2) A simple communications protocol that uses a physical star topology and can easily be implemented on a low end uC?
I've got a few other ideas, but if one of the above exists then I think I can come up with a better design.
TIA
Can anyone suggest:
TIA
