SeanHatch
Hello, I am building a monitor interface for a freescale microcontroller, and I have some questions about the schematic.
The schematic can be found here:
on page 165.
First of all, I'm looking to buy most of my parts from digikey, but they don't have one of the ICs in the schematic. Since the uC is a motorola thing, all the ICs are motorola too, but I figure there has to be a replacement for it. Here is the datasheet for the missing IC
http://www.datasheetcatalog.com/datasheets_pdf/M/C/1/4/MC145407.shtml
Also, on the far left of the schematic, you see some arrows marked 2,3,7. DB-25 is written above this. I don't know what this means. I assume it is the serial connector or something, but not sure.
Finally, in the center of the circuit you see the 6Mhz oscillator. You can either select that or that other little circuit (see note three). I'll have to build the 6MHz oscillator right? You can't just pick one these things up can you? and for the other 6mMHz option, what is that circuit symbol in parallel with the 10M resistor?
I know this is vague, but any help is appreciated. Thank you
on page 165.
