Help with active filters
Mothra
Hello,
I am currently in college and working on a final project. It is a 5-channel color organ made up of 5 active filters (opamp sallen-key filters to specify). This may seem like a stupid question but if these filters are of unity gain, do the opamps need a DC supply voltage? If so, how do I determine the DC supply voltage to use?
Thanks in advance
The supply voltage needs to be greater than the signal P-P. Most amplifiers cannot pull their outputs to the + and – supply pins. If your signal is 5 volts pk or 10 volts p-p then the amplifier needs 3 volts head room so you need +8 volts and –8 volts minimum. If your signal is AC coupled and is centered around ½ supply then you need 16 volts of supply.
Do op-amplifiers (with a gain of 1) need a supply voltage?
Does your car need a motor to go on a flat road?
Gain of 2 = uphill.
Gain of 0.5 = down hill. (keep the motor running)
