cluelesshillbilly
How much heat could I produce if I assembled four 25 ohm, 25 watt, Cement Type Wirewound Resistors in front of two fans in a 4 cubic foot space? I was planning on housing them turned 45 degrees (for better aerodynamics) in a small metal box with two 2 inch fans recirculating the air in the enclosure over the resistors.
The specs:25 ohm, 25 watt Wirewound Resistor from Madisound
5mm Ø Ceramic Core, Perfect Winding, Solder plated copper leads, 10% Tolerance"
25 watt resistor dimensions
60 mm long
14 mm tall
15 mm wide
35 mm long leads
Thanks Everyone!
60 mm long
14 mm tall
15 mm wide
35 mm long leads
Thanks Everyone!
