Exponential waveform
You can periodically charge and discharge a capacitor through a resistor using a pulse source.
Hi
Use an EXP voltage source and trigger it with a second voltage source.
Set the trigger voltage source "cycles" for the desired number of cycles.
See example attached.
Hi eTECh
Thank you very much for your solution , wanted something like this only .I created exact schematic as yours but while simulating its giving me this error . i will attach the the snapshot
Hi eTECh
It works fine on my system. Make sure your running the latest version of LTspice.
Else, attach your ,asc file and I will test.
Hi eTECh
Already updated my version of LT Spice , still its not working . I will attach the .asc file for your reference
  • Draft1.asc
Hi eTECh
Hi
The problem with your schematic is that the TRIGGER statement is not entered as part of the EXP statement. You've added it to the schematic as a separate statement.
To fix this:
1. Delete the "TRIGGER" statement
2. Rht-click the "EXP" text on the schematic, then add the TRIGGER statement at the end of the EXP statement. Then click OK.
I've attached a corrected version of the schematic.
  • Draft1-fixed.asc
