Electromechical transducer theory
walters
Banned
Transducer- changes electrical motion into mechanical motion
in electronics there is capacitors,inductors,transformers,transistors,resistors
for using electrical motion
What would be a capacitors,inductors,transformers,transistors,resistors
for mechanical motion? this is my problem because i don't know what
a capacitors,inductors,transformers,transistors,resistors is for mechanical
motion?
How can i use this mechanical motion to get phase shifting like electrical motion with a capacitor or with a inductor?
Changes the current or voltage flow it alters the Flow for electrical motion
how can i change the flow of the mechanical motion like a capacitors,inductors,transformers,transistors,resistors does in electrical motion
in mechanical motion i don't know what a capacitor is for mechanical energy or motion flow?
in mechanical motion i don't know what a resistor is for mechanical energy or motion flow?
in mechanical motion i don't know what a inductor is for mechanical energy or motion flow?
be a spring, and a gear ratio
but how would i use the spring or gear ratio to be like resistor,capacitor
to get phase shifting also
Trying to convert audio electronic signals into mechanical signals
so i can alter and change the flow of mechanical energy like electronic circuits
do but do it with mechanical circuits just like electronic circuits
example 1.) phase shifter electronic circuit
uses phase filters
what would this be for mechanical circuit?
what would i use to shift the mechanical energy or motion to give
a phase shift?
2.) Bandpass,Notch,Highpass,Lowpass filter electronic circuit
What would this be for a mechanical circuit?
what would i use to make a mechanical filter circuit?
Tools used: Levers,flywheels,springs,gears
What can mechanical motion or energy Flow through?
What can Alter the mechanical motion or energy?
