bmb99a said:My PC's media player and Winamp and windows's other sound's are too fast playing. I have tryed to doing partitioning and formatted, then installed windows again.
I have tryed to install drivers for my soundcard. But it still.
Does anyone knows what should I do?
Thanks a lot. How can I check out in the device manager what speed settings are used? I can't find the speed settings.Boncuk said:That's definitely not a problem of the sound card or the driver. It is an OS problem. Check out in the device manager what speed settings are used. Check 'normal' if it is set 'high'.
Thanks a lot. Do you have Realtech HD audio? If so, please send to me. Thanks.mvs sarma said:It must be using Realtech HD audio. on the task bar there will be a button for it. right click and open. Otherwise you may go thro' Control panel also.
On the right side you find a button called Karoke
it has clickable bttons Up and DOWN and a counter reading its value. this must be showing "one or "2" in your case.
Set it to "ZERO"
Click OK and come out. now you try playing a song / music.
everything will be OK
Thanks a lot. I will try.picasm said:More info about your sound card, motherboard and windows version would have helped.
Perhaps you have the wrong sound card driver. If it is a sound card built-in to the motherboard, then you need to check it on the manufacturers web site as they sometimes have several possible drivers depending on the exact motherboard revision.
You don't say what version of windows you are using, perhaps you need to install servicepacks which may fix problems if using the default Microsoft drivers.
Get the latest drivers from the sound card manufacturer and if all that does not work, try with a different sound card.
Realtech HD audio driver is not something to be ziped and sent.bmb99a said:Thanks a lot. Do you have Realtech HD audio? If so, please send to me. Thanks.
