mashersmasher
what's the best technique for desoldering chips. i want to take a some chips out of a board (not sure where it came from) and experiment with there usage. i however do not know how to desolder them effectively
dknguyen said:A soldering iron and copper wick is probably your best bet as far as cost goes.
3v0 said:I have been beat up for this by the poeple on the EDA board so use at your own risk.
In some cases I find it useful to apply MORE solder prior to desoldering.
It seems wrong but the solder help conduct heat to the pins where it is needed. Solder is a much better conductor of heat then the board itself. The additional solder may prevent the board from cooking.
Nigel Goodwin said:Perfectly standard procedure, I almost always use it, it's particularly good for lead-free solder, apply extra leaded solder and it comes off MUCH easier.
killivolt said:I do it this way on surface or thru hole if it is thru hole an if the pins have been bent on the other side then use the iron and new flux and solder to bend back to straight as possible.
crust said:There was a post on hackaday a while back about building a hot air rework gun from a bulb type desoldring iron and a air source (which I seem to recall was a fish pump, but not sure).
