paul9531031
I have tried to solve the problem of cycle indicator lights, and made a flasher circuit using a 555 timer, 7.4 volts from two Li-ion batteries, and BA15S 5050 160 lumen LED bulbs. The problem is that the light is not bright enough for motorists to notice in sunlight.
I have a feeling that I should be using a much more powerful LED and make it flash for micro-seconds by charging a large capacitor (possibly with a voltage pump) and then discharging it to the LED every half second, on the assumption that the overall energy used will be similar but the visibility will be far better.
Can anyone say if this is a correct assumption, and if there is a standard solution to get a very bright short flash from an LED?
With thanks for any response.
