Wait hold on! I think you said the timing was different between the boards. I that case one of the caps or one resister must be different. Should not have any baring on the parts you are replacing but thought you should know.Well once I get everything assembled I will have to see how it functions. If 2 seperate boards have same parts then they should act the same.
Ron; This doesn't even Look close. The OP boards use logic level thyristors not triac's.
Hay thanks for trying. Looked for a while for a similar circuit and could not find one.Sorry and back to the drawing board.
Ron
Yup my thanks too. Be my luck the only resistor that could be different is the burnt one. Is there safe way to experiment resistors if I had to?Hay thanks for trying. Looked for a while for a similar circuit and could not find one.
It should be about the same as the one on the good board.Is there safe way to experiment resistors if I had to?
Ok. I got all the info for everything..thanks guys..it will take some time to get it complete. I will notify the end result.It should be about the same as the one on the good board.
I did give info on cap. Its here or post 34View attachment 60249 here is configuration from the bottom
