I am using this Omron sensor (EE-SX674A) to connect to a PLC (Kinco PLC- wiring diagram), see page 4 for internal connection of sensor.
The PLC however is wired to receive only PNP type input as some of the Input ports are wired as PNP.
Can this sensor output be converted to PNP type by connecting a pullup resistor (tied to +24 VDC) ? If I use a 2.2K resistor will this work ??
The voltage of the PLC is +24 VDC. The sensor also operates on +24 VDC.
I could use a PNP type sensor instead, however I have lot of stock with me, I don't want to buy a new part. And since there is extensive re-wiring involved for converting the input port to PNP, I think it would be easier to just connect some pull-ups instead.
thanks
a
thanks
a
