comparator dead zone
Joe G
i've been playing around with comparators lately learning how they work. but my question is, is there a way to make them have a dead zone instead of being either sourcing or sinking, i've looked for a while and can't figure out if it is possable.
You can have high or you can have low but there is no in the middle. :)
You can apply hysteresis to keep them from bouncing but I don't know of a tri state comparator. That does not mean one does not exist only that I am not familiar with it if it does.
Ron
i was working on a linefollowing bot but i wanted it to have frt wheel steering. i finished it on a breadboard. but i was trying to eleminate a relay. i didnt want it to zigzag,. but stay on the same direction untill the sensors changed it. and i tryed to figure out if there was a way to make a comparator do that :)
It's called a window comparator, you make that with 2 comparators. It has 3 outputs : above window, below window, inside window.
Yeah, but you still only have 2 states correct? Above or below are a state just like in the window is a state.
Ron
Joe G
I have make up a sketch of a voltage follower. But I have added a small grid of bjt's around it to make it possible for it's output impedance to become high.
I haven't been able to test it on a bread board, but if you're interested of testing the concept, I can draw it. But then you must agree to post a detailed report back on this forum.
i think ive figured out a way to do want to accomplish, but haven't been to the breadboard as of yet, if it works, i can finish construction and make a new post of my outcome :)
Hi Joe,
you might look at this design.
It's a 3 point floating comparator, used for a solar tracker.
Boncuk
is the solartracker circuit for use w/ a controler? cause i'm not able to use them as of yet :(
The solar solar tracker is a stand alone circuit working without microprocessor. Just take a look at the OpAmps and the circuitry after them which control two motors via miniature relays (forward and reverse).
Boncuk
