COM and USB port protocols
I'm hoping someone can help me!
I know that a COM port on a PC uses RS232 protocol to communicate with external devices etc. But what does USB use? Is it the same as RS232, or does it have a different protocol? If so, does anyone know what it is? Thanks.
Any info will be appreciated.
evandude
the usb is a million times more complicated than RS232... Don't have any real helpful info for ya... but it's not anywhere near as simple and elegant as RS232. a whole lot faster, though, of course.
Super Moderator
Most Helpful Member
USB uses.... I guess USB.
However, you can buy converters to plug into the USB which will give 1 (or more) RS232 ports. Also converters from USB to parallel (Printer).
plot
USB uses an encoding technique called NRZI, it's serial just like COM... only, different format, works at different voltage levels a different way, etc...
usb.org is a good place to find stuff, alot of it is mumbo jumbo advertising type of things... but you can find the full data sheet specs for USB on there if you look hard enough.
Nigel Goodwin
Super Moderator
Most Helpful Member
If you look on the Microchip website they have an application note for their USB capable PIC's (the 16C745) - this shows what's required at both the PC and PIC sides.
As already suggested, it's a LOT! more complicated than RS232.
EE World Online Articles
Loading
