Note: This feature currently requires accessing the site using the built-in Safari browser.
DEVICE PIC16F887
Define CONFIG1 = 0x23e4 '23e4
Define CONFIG2 = 0x3eff
OSCCON = %01110101 'Oscillator control (datasheet page 66)
'Defines the parameters of the LCD interfacing
Define LCD_BITS = 4
Define LCD_DREG = PORTD
Define LCD_DBIT = 4
Define LCD_RSREG = PORTD
Define LCD_RSBIT = 2
Define LCD_EREG = PORTD
Define LCD_EBIT = 3
Define LCD_RWREG = PORTD
Define LCD_RWBIT = 0
'Defines the parameters of the PSI interfacing
Define SPI_SCK_REG = PORTC
Define SPI_SCK_BIT = 3
Define SPI_SDI_REG = PORTC
Define SPI_SDI_BIT = 4
Define SPI_SDO_REG = PORTC
Define SPI_SDO_BIT = 5
Define SPI_CS_REG = PORTD
Define SPI_CS_BIT = 0
SPIPrepare
AllDigital 'alle ports digital
'declaring variable
Dim ledgreen As Byte
Dim data As Byte
'A gate set to the desired value
'76543210
PORTA = %00000000 'make all ports "PORTA" low
TRISA = %11101111 'RA7,RA6,RA5,RA3,RA2,RA1,RA0 are set for input. RA4, is set for output!
ANSEL = %11000010 '1 = Analog input, RA1,RA6 and RA7 are set for analog input, 0 = digital input, RA0,RA2,RA3,RA4 and RA5 are set digital I/O input.
'B gate set to the desired value
'76543210
PORTB = %00000000 'make all ports "PORTB" low
TRISB = %11111111 'all ports are set for input
WPUB = %11001010 'weak pull-up portB register. 1 = pull-up enabled 0 = pull-up disabled (datasheet page 51)
'C gate set to the desired value
'76543210
PORTC = %00000000 'make all ports "PORTC" low
TRISC = %10111001 'port RC1 & RC2 (CCP1 & CCP2) are set for output
'D gate set to the desired value
'76543210
PORTD = %00000000 'make all ports "PORTD" low
TRISD = %11111111 'are set for input
Lcdinit 0 'no cursor
ledgreen = 1 'turn on the green led!
SPICSOn 'select the RTC bij pulling CS low
SPISend 0x12 'send the write command
SPISend 0x01 'send address for 'seconds'
SPISend 0 'set seconds to zero
SPICSOff 'deselect the RTC bij pulling CS high
main: 'endless loop
SPISend 0x13 'send the read command
SPIReceive data 'recieve data and store it in 'data'
Lcdcmdout LcdClear
Lcdout "Sec "
Lcdcmdout LcdLine1Pos(5)
Lcdout #data
WaitMs 100
Goto main
End 'end program
Not the best way to spend a Sunday!!Today I spent the entire day with the SPI bus.
SPISend 0x80 'set seconds to zero
