circuit needed
mart_1986
hi there
im making electronic blinds on a timer but i need a circuit that will make the motor go forward till it hits the limit switch then i need it to reverse the moter for when the eletric timer kicks in again to close the blinds until it hits another limit switch then reverse it ready for opening again
my timer is just 1 that plugs in to the wall
does this make any sense
you should use a pic with a relay for that. when it receives a signal for the timer the pic brings a pin high going to a transistor going to a relay controlling the motor in the blinds. then when limit switch is pressed the motor stops. after the timer sends another signal it moves the mother in reverse closing the blinds until the other limit switch is pressed.
