Monkeyman87
I have my accelerometer project working now. I can get 10 bit acceleration values from the PIC Excel succesfully. Since my project is for a science fair I need to do an error analysis. I have to run the accelerometer along a marked path of one 1 meter then do calculations in Excel to find the distance. I'm using the time and the accel value to calculate the distance. D = t*t*a So if my sampling rate is 1 hz I use 1s as time and the acceleration value and calculate distance. The real problem is in my derivation of the acceleraton value. The PIC inputs a value to the PC from 0 to 1023 corresponding to the acceleration. When I get the data in Excel I take the value and subtract it from the value for zero g. If the number is below the 0g value then the accel is negative and if above then vice versa. If thats clear enough my problem is what value to use for zero. If the data deviates 1 count for 1s at a 1khz sampling rate it adds up to alot of error. Any thoughts or suggestions? Also I thought maybe if I took an average of the values when it is sitting still, that would work as a 0g value.
Really, thanks for your help I can use it!!
