Blanking the retrace - Analog scope
atferrari
Most Helpful Member
I managed to show on my scope a symbol formed by several dots by controlling voltages at the X-Y axis.
To make it neat I would need to blank the retrace between dots.
My scope is an old analog TRIO 10 MHz CS1562A. Couldn't find the manual but a PDF version found in the Web says that "modulation" may be done "at TTL" levels.
Just in case, I tried myself bringing the Z axis input to 0V and 5V, getting only a change in brightness.
Is it any way I could blank completely the retrace in between spots?
I suggest you consult the circuit, and see if applying more voltage will blank it further - but it may be as far as it's supposed to change. Z inputs I've looked at in the past require LARGE voltage changes, as the essentially drive the cathode (or grid) pretty well directly.
Thanks Nigel
You were online, I can see. Thanks for replying,Nigel.
I am affraid of trying any different from the manual because of that of "TTL levels". It is the only scope I have and no money to replace it in the near future...
Would you say that it could be safe to try any different?
Z axis input
There are several transistors between the Z input and the grid in question.
I presume, it precludes applying any high voltage to it.
Try reducing the trace intensity. You may find a point where the beam is blanked but still retains sufficient intensity to see the dots.
Problem solved
Problem solved: applying -5V to the input did the trick. :)
Gracias to you both for replying.
