Battery Charger Amps
Thank you for your help I will post a photo of the finished project to enable others to see .
A photo is as good as a 1000 words and this could help others.
Greg
I found out the 3 phase regulator from my larger motorcycle was actually not bad. So, I soldered wires to each connector, and hooked it up to the ATC. Turns out that bridging phase inputs doesn't affect output at all. I grounded one phase input, and hooked the other to the one wire output of the stator. The inflator turns much faster with only the rectifier. A regulator seems to just kill the output of the stator.
How do I test my IRF Z24N Power Mosfet Rectifier.
I think it is not working.
I have made a 1 ohm resistor out of resistor wirer. When the motor is running the wirer glows red.
I can not adjust the voltage and the charge voltage is 12.45 V dc.
The risister I have made would this have caused my problem.
I will post a photo of the board.
