Air hockey Table
azmaster
Hi i am making a air hockey table for my GCSE electronics course.
I wanted to know if the following idea would work and if possible any help. as i am only young could you only post links with simple electronics. Thanks
anyway I wanted to find this out would it be possible if i use the following:
2 14-M2 picaxe microcontrollers which will control 7 LEDS on both sides as a counting system and either two motion sensors or microswitches.
1 08-M2 picaxe microcontroller which will operate the microswitch controlled coin sensor and the fans applying the air.
Thank you
Just adding I also need to know how to connect several microcontrollers because for the 14 M2s microcontrollers i need them to be connected to the fans so they turn off when the score reaches seven.
Here are my pic axe programmes are they ok?
