Adjustable voltage regulator
you want the input to be at least 30V and be capable of processing 5 to 10A? What is the output voltage range going to be? Any output that is significantly lower than 30V is going to heat your house.
I'm sorry I made a error in the link to the data sheet. Here is the data sheet for the LT1083CP and it is an adjustable regulator. If you need some I have a small qty that I would be willing to share with you.
NED
  • LT1083CP.pdf
Your Gonna Need More Packages To Dissapate The Heat.how About A Variable Inductace Foward Converter ,or Stepped Pre Regulator?
Edge
You could just add Transistors to the output of a small regulator.
A couple more
When a voltage regulator has emitter follower transistors on its output then the output of the circuit has lousy voltage regulation.
It also does not have current limiting.
Yes, the LM723 has the output transistors inside its negative feedback loop so the output voltage is regulated properly. It also has current limiting.
Night Rider said:
Hi there,
I'm looking for an ic much better from LM338 and LM396. 5-10A but more voltage >=30V.
Thanks!
You really need to look at switchmode power supply controllers... and probably a microcontroller controlled one at that.
Try Microchip's "power solutions" pages to see what they have.
P.
Ok guys,
Thanks for your ideas.i have in my mind all of this but i was thinking for an ic. I'm programming pic's but i'm running out of time to design somethink like that. I made the supply but i'm not very satisfied. 2 channels 0-75V/5A, 1 channel -75-0V/5A, 1 channel 5V/5A. It is very complex and when i added current regulator some problem was occurred. i'll make something more simply. Sorry the bad english.
Thanks again for your ideas. When i'll make something about this i'll publish to you.
