Accurate Temperature Sensor
Soda Ant
I was planning to use an LM75 for a temperature sensor for a weather station I'm building until I read the datasheet and found that its accuracy is only +/- 2C.
Is there another sensor I can use that's accurate to +/- 0.5C in the temperature range -10C to 50C?
Dallas semiconductor makes several good choices for accurate temperature measurement.
Why do you need that accuracy?
Maxim (aka Dallas Semiconductor) carries single chip silicon-based temperature sensors accurate to 0.5C:
The DS600 is the only analog output device they have with that accuracy:
THe rest are digital interface such as the DS620 or DS7505:
Needless to say, you could do the same thing with an RTD (with a much greater stability and accuracy over a much larger temperature range) at greatly increased cost, complexity, and hard to find parts.
If I were building a weather station that I wanted to be taken seriously, I'd want that kind of accuracy. Same for wind speed and rainfall.
Dean
if you have a computer involved you can add a calibrate function to that program. this avoids the additional expense of more acurate sensors
