Hi all,
It is said that if you connect two batteries of different values in parallel,them the lower value will be obtained as output.If that is the case then how is it that a 7 segment led connected in common anode configuration with single resistor work?..because no two diodes will have the same cut in voltage and you can still get a display with all 7 led's glowing eg:no.8 for a 7segment display
