Hello members,
What i need help/suggestions with is concerning heating a plate thru which cold air flows on it's course to the face mask. This plate is designated as number "3" in the drawing (page 1). Not sure rather:
1. To simply thread nichrome coated wire thru said plate
2. Increase the number of plates.
3. Use (2) 5 watt power resisters in series (as i need 10 watts) of which i have no idea how to do
4. Or dispense with the plate concept altogether and coil coated nichrome wire around the outside dia. of the aluminum tube using it as a heat sink(#4 in the drawing on page 1)
What i am concerned about is will the air have enough time in passing thru the chamber to bring it up to the 60-75 degrees i need for breathing.(I have copd and cannot tolerate air below 45 degrees for long which makes me a virtual prisoner in winter)
Mask (shown on page 2) has a one way outlet valve.
The arithmetic is mostly worked out (By other. See page 6)
With air flow volume at 50 liters/min and temperature at 27 degrees 8 watts is needed to bring air up to design temperature of 60-70 degrees. (Taking a 10 watts figure)
On order at present (links are on page 3)
1. -temperature controller.
2. -sensor to warn me when my battery falls below a certain voltage.
3. -5000mAh 11.1 volts battery-rechargeable Lipo Pack
This has been a bit long but i wanted to include enough info.
Thanx for any time you may have to address my problem.
