april
I found when designing a circuit that when for some reason the 7805 is not grounded properly it output the input voltage?
I fed it with 12 Volts in and intended the feed of 5 Volts for an ATTiny85.
There was a break in my circuit back to ground and 12 V hit the ATTiny85 destroying it .
Would a safer approach be to put a 5.5Zener across from the 7805's output to ground . Of course this will not work if it is not close to the Negative board connection . putting it across near the 7805 would not achieve much.
Are there any other approaches to use when using 12V alongside 5V chips?
