I have connected the output pin of a 741 op amp into a 74HC04 directly
The 74HC04 output sadly doesn't invert the output against input
I have daisy chained all 6 of the gates in the 74HC04 so as to avoid problems with floating inputs.
As this is bread board project so far, by isolating I have proven that the 74HC04 inverts through all of its gates perfectly, it is working fine.
The 741 output pin swings High / Low perfectly according to it's inputs, so it too is fine.
But when I connect 741 into 74HC04 it fails to work as hoped
What is the correct interface between 741 and a 74HC04 ?
Any ideas will be greatly appreciated
Many Thanks
Les
Many Thanks
Les
