The circuit looks correct. If everything is properly connected, touching any of the leads should have no effect. Sounds like a bad connection somewhere.joshua17ss2 said:That is the basic lay out i used. the i had the resistor connected to the base, and the 5 volt supply connected to the resistor, the ground from the relay and the supply shared the emiitter, and the 24 v control line to the collector.
i used a 5volt power supply to sub for the microcontroller at the moment, i just used a momentary switch in line with the base
