00-99 COUNT UP & DOWN USING PIC16f887a
AnneMaj
i really need help here..
i need an assembly program for my project..
Make a program that will count up from 00->99 and can count down from 99->00
Requirements:
a. one push button for count up
b. one push button for count down
c. 2 7-segment display (common cathode)
d. use multiplexing tech. (or use only PORTB as output)
e. you may use PORT A,C,D or E as input.
ex.
the display is 00, when i press the button for count up once, it will change to 01. and by clicking again will change to 02 and so on.
ex.
the display is 09, when i press the button for count down, it will change to 08.
help please..
You have all you need to make one on the page I posted all you have to do is change the code Mike posted to work with your chip.
Look at post4 its for a 16F88 it's still asm and it will work with some changes on your chip
Now is your chip really a 16F887 or a 16F877a there is no 16F887a.
OP might be multiplexing the displays to reduce I/O pin requirements. Using "direct drive" from I/O pins could provide about 20 ma 'peak' current or about 10 ma 'average' current to each display segment at a 50% duty cycle which should be pretty bright.
2-digit-up-down-png.30263
Hundreds of ways to do the software. OP might consider using one big isochronous loop or perhaps use an ISR (interrupt service routine) to refresh the displays as a background task.
I'm surprised OP couldn't find any 2-digit 7-segment up/down counter examples on the Internet.
Kind regards, Mike
<added>
A quickly thrown together (untested) isochronous loop program example;
;  2-Digit Up/Dn Counter, Isochronous Loop Example                *
        processor PIC16F88
        include "p16f88.inc"
        errorlevel -302
        __CONFIG  _CONFIG1, _LVP_OFF&_PWRTE_ON&_WDT_OFF&_INTRC_IO
        __CONFIG  _CONFIG2, _IESO_OFF & _FCMEN_OFF
ones    equ     0x20            ; 0..9
tens    equ     0x21            ; 0..9
number  equ     0x22            ; 00..99
swlatch equ     0x23            ; switch state latch variable
DelayHi equ     0x24            ; DelayCy() subsystem variable
#define DnSw    3               ; RA3
;  K8LH DelayCy() subsystem macro generates four instructions
        radix   dec
clock   equ     8               ; clock frequency in Megahertz
usecs   equ     clock/4         ; cycles/microsecond multiplier
msecs   equ     usecs*1000      ; cycles/millisecond multiplier
DelayCy macro   delay           ; 11..327690 cycle range
        movlw   high((delay-11)/5)+1
        movwf   DelayHi
        movlw   low ((delay-11)/5)
        call    uDelay-((delay-11)%5)
        endm
;  init hardware and program variables
        org     0x000
Init
        bsf     STATUS,RP0      ; bank 1                          |B1
        movlw   b'01110000'     ;                                 |B1
        movwf   OSCCON          ; select 8-MHz INTOSC clock       |B1
Stable  btfss   OSCCON,IOFS     ; INTOSC Freq Stable bit set?     |B1
        goto    Stable          ; no, branch, else                |B1
        clrf    ANSEL           ; setup PORT A for digital I/O    |B1
        movlw   b'00001100'     ;                                 |B1
        movwf   TRISA           ; RA3-RA2 inputs, others outputs  |B1
        clrf    TRISB           ; portb all outputs               |B1
        bcf     STATUS,RP0      ; bank 0                          |B0
        clrf    PORTB           ; clear portb output latches      |B0
        movlw   b'00000001'     ; digit select bits (RA1-RA0)     |B0
        movwf   PORTA           ; select the 'ones' display       |B0
        clrf    swlatch         ; clear switch state latch        |B0
        clrf    ones            ; clear 'ones'                    |B0
        clrf    tens            ; clear 'tens'                    |B0
        clrf    number          ; number = 00                     |B0
;  isochronous 8 msec main program loop (62.5 Hz refresh rate)
Main    clrf    PORTB           ; blank the display               |B0
        movf    PORTA,W         ;                                 |B0
        xorlw   b'00000011'     ; flip digit select bits          |B0
        movwf   PORTA           ;                                 |B0
        movf    tens,W          ; WREG = tens, 0..9               |B0
        btfss   PORTA,1         ; display tens? yes, skip, else   |B0
        movf    ones,W          ; WREG = ones, 0..9               |B0
        call    segtbl          ; get segment data                |B0
        movwf   PORTB           ; display new digit               |B0
TstSw   comf    PORTA,W         ; sample active low switches      |B0
        andlw   b'00001100'     ; on RA3 and RA2 pins             |B0
        xorwf   swlatch,W       ; changes (press or release)      |B0
        xorwf   swlatch,F       ; update switch state latch       |B0
        andwf   swlatch,W       ; filter out "new release" bits   |B0
        bnz     Bump            ; branch on a "new press", else   |B0
        DelayCy(8*msecs-23)     ; precise 8 msec loop timing      |B0
        goto    Main            ;                                 |B0
;  bump 'number' up or down with limit checking
Bump    andlw   1<<DnSw         ; the "Dn" switch?                |B0
        skpz                    ; no, skip (WREG=0), else         |B0
        movlw   -2              ; WREG = -2 (dn)                  |B0
        addlw   1               ; WREG = 1 (up) or -1 (dn)        |B0
        addwf   number,F        ; number++ or number--            |B0
        movf    number,W        ; WREG = number = -1..100         |B0
        xorlw   100             ; test upper limit                |B0
        skpnz                   ; upper limit? no, skip, else     |B0
        decf    number,F        ; reset to 99                     |B0
        btfsc   number,7        ; lower limit? no, skip, else     |B0
        incf    number,F        ; reset to 00                     |B0
        movf    number,W        ; WREG = number = 00..99          |B0
;  setup 'tens' and 'ones' for next loop
        clrf    tens            ; isochronous bin2bcd routine     |B0
        addlw   -80             ; W = W - 80                      |B0
        rlf     tens,F          ; shift in 2^3*10 bit             |B0
        btfss   tens,0          ; borrow? no, skip, else          |B0
        addlw   80              ; W = W + 80                      |B0
        addlw   -40             ; W = W - 40                      |B0
        rlf     tens,F          ; shift in 2^2*10 bit             |B0
        addlw   40              ; W = W + 40                      |B0
        addlw   -20             ; W = W - 20                      |B0
        rlf     tens,F          ; shift in 2^1*10 bit             |B0
        addlw   20              ; W = W + 20                      |B0
        addlw   -10             ; W = W - 10, now W = "ones"      |B0
        rlf     tens,F          ; shift in 2^0*10 bit             |B0
        addlw   10              ; W = W + 10, now W = "ones"      |B0
        movwf   ones            ; save "ones"                     |B0
        DelayCy(8*msecs-54)     ; precise 8 msec loop timing      |B0
        goto    Main            ;                                 |B0
;  segment data table (caveat, non-boundary tolerant)
segtbl
        addwf   PCL,F           ;                                 |B0
        dt      b'00111111'     ; "0"   -|-|F|E|D|C|B|A           |B0
        dt      b'00000110'     ; "1"   -|-|-|-|-|C|B|-           |B0
        dt      b'01011011'     ; "2"   -|G|-|E|D|-|B|A           |B0
        dt      b'01001111'     ; "3"   -|G|-|-|D|C|B|A           |B0
        dt      b'01100110'     ; "4"   -|G|F|-|-|C|B|-           |B0
        dt      b'01101101'     ; "5"   -|G|F|-|D|C|-|A           |B0
        dt      b'01111101'     ; "6"   -|G|F|E|D|C|-|A           |B0
        dt      b'00000111'     ; "7"   -|-|-|-|-|C|B|A           |B0
        dt      b'01111111'     ; "8"   -|G|F|E|D|C|B|A           |B0
        dt      b'01101111'     ; "9"   -|G|F|-|D|C|B|A           |B0
;  K8LH DelayCy() subsystem 16-bit timing subroutine
        nop                     ; entry for (delay-11)%5 == 4     |B0
        nop                     ; entry for (delay-11)%5 == 3     |B0
        nop                     ; entry for (delay-11)%5 == 2     |B0
        nop                     ; entry for (delay-11)%5 == 1     |B0
uDelay  addlw   -1              ; subtract "loop" cycle time      |B0
        skpc                    ; borrow? no, skip, else          |B0
        decfsz  DelayHi,F       ; done?  yes, skip, else          |B0
        goto    uDelay          ; do another loop                 |B0
        return                  ;                                 |B0
        end
i need help.. can you help me with these?
00-99 COUNT UP & DOWN USING PIC16f877a
Requirements:
ex.
ex.
help please..
16f877a..
what do you mean on the changes on my chip?..
won't i need to change the program?..
Lol all you had to do is this and test it.
Look it over real good
; change the chip name and configure
      list		p=16f877A	; list directive to define processor
	#include	<p16f877A.inc>	; processor specific variable definitions
	__CONFIG _CP_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _HS_OSC & _WRT_OFF & _LVP_ON & _CPD_OFF
        radix   dec
        movwf   DelayHi
        endm
        org     0x000
Init
; change the ADC stuff
        bsf     STATUS, RP0     ; Select Bank 1
        movlw   0x06            ; Configure all pins
        movwf   ADCON1          ; as digital inputs
        movf    PORTA,W         ;                                 |B0
        movwf   PORTA           ;                                 |B0
        goto    Main            ;                                 |B0
        goto    Main            ;                                 |B0
segtbl
        addwf   PCL,F           ;                                 |B0
        return                  ;                                 |B0
        end
Wire it up to the same pins as the picture
This is a 16F88 but your chip has the same ports PORTA and PORTB
This Is Mike K8LH Work I just reposted it to help you out and changed code to work with your chip.
        radix   dec
        movwf   DelayHi
        endm
        org     0x000
Init
        movf    PORTA,W         ;                                 |B0
        movwf   PORTA           ;                                 |B0
        goto    Main            ;                                 |B0
        goto    Main            ;                                 |B0
segtbl
        addwf   PCL,F           ;                                 |B0
        return                  ;                                 |B0
        end
it's not working.. :(
Hi AnnaMaj,
Post the changes you have made to the code then we can see where you have gone wrong.
Can you describe in a little more detail what you have done to determine that?
Here are some thoughts:
1) Is that conclusion based on a breadboard circuit or simulation?
2) What simulator are you using?
3) Bypass the delays (comment out) and step through the rest of the program. What happens? Post the code from your simulation.
4) If you are not using a simulator, such as MPLAB SIM, it is difficult to troubleshoot code.
5) If breadboard, is anything happening? That is, is it totally dead, or are some led's coming on, but they are not quite right?
6) Is the code you posted a copy and paste of your actual Assembly code or simply copied from what's been posted here? In other words, it is crucial to determine whether some unintentional changes have slipped into the code you are using.
7) I haven't had breakfast yet, but I don't see the HS crystal resonator in your schematic. See Chapter 14.2 of the datasheet.
The above list is not exhaustive.
John
hi AnnaMaj
It works for me in the Oshonsoft simulator.:rolleyes:
E
She or he may not be using the right crystal mikes code
Was for a 16f88 at 8 MHz
I changed the code to run on a 16f877a you need a crystal on that one
May of left crystal out but I'm sure the code works
John
this is based on simulation (ISIS)..
sorry cause im new in this and i still dont know much.. thats y i need help..
i dont still dont understand much.. :(
do i still need to change the codes?
It works on hardware with a 8mhz crystal. That is how i tried it dont like ISIS.
