The 4528 is a dual mono.huttojb said:any chance for a part number
Jason,huttojb said:This is a very good idea but I'll be controlling relays as the same time, i.e. I might switch a relay on, then 10 seconds later I might switch another, 750mS later I'll switch another 50mS I'll switch another and so on.
If there was gonna be a 1.5S gap between each Relay being active this would work a treat. The problem is the Relay switching will be completly random.
I agree with these statments.ericgibbs said:Regarding PIC failure, it is also possible that the PIC output could fail in the +V output state as well as the 0v state.
If the failure of the PIC could cause a fire, your basic system is flawed.
You should re-examine the relays rating, if its continously rated and run at the correct voltage, within its specified operating temperature, it should NOT catch fire.
Any idea why it gets hot???
Are using a relay with only an 'intermittent use' rating??
Eric
Yes, it is binary.huttojb said:Can I ask a question, does a shift reg basically work on the binary way??
So if I connect 4 relay's on D1, D2, D3 and D4. If I only want D4 on how would I do this??
Yes, the operate and release times of relays and other electromagnetic devices is in the millisecond region due to physical initeria and the inductive time constant.huttojb said:So your saying. you switch D1, D2, and D3 on then off but as the relay has a pull in time, the relay doesn't pull in??
Jason
