"Alternating" being the operative, definitive adjectival gerund...
To put a finer point on it, the alternating voltage needs to be up and down in value, over a specified period of time, not merely a linear change like, say, the simple depletion or recharging of a battery.
Within the OP's graphs second example, it is a DC biased AC signal; the two elements (DC and AC) need to be considered apart from one another when discussing the waveform's (or "signal's") definition(s).
The bias is clearly DC (NOT alternating) while the voltage riding the bias is clearly AC (alternating). As we all know, stick a cap in the signal path and the DC disappears, leaving the AC.
Now, what of the case of a positive (or negative), slowly alternating DC bias (therefore an AC signal) upon which is riding a more (or less) rapidly varying AC component? Here again, the two AC components would merge (mix) such that the resulting signal would still be composed of a single AC signal riding a DC bias, more properly considered a biased modulation. The subsequent signal might well pass across zero, but the DC part could still be isolated from the AC part for definition purposes.
