Phillips PM3256 Oscilliscope - How to make Lissajous figures ? - help please
teutonic
Hi
I could use a little help. I love my ebay sourced scope ( Phillips PM3256 ) but the trigger control switches are baffling me when I try to create lissajous figures.
Can any gurus guide me. ? The scope does'nt have a XY button, it has a XDEFL button which I think does a similar thing but I'm getting bogged down with all the button choices. Heres a pic of the buttons. Can anyone tell me what to choose for Lissajous figures generating ?
And I just put 'sinewave a' in ch1 and 'sinewave b' in ch2 I think. ? Should I be using the 'hold off' or an external trigger when I try this ? Also is a 'huntron' any good to me ? I made one but not sure why lol :)
Thanks for any help with the buttons I'm grappling with.
There is no trgiggering as there's no timebase for doing lissajous figures, I would imagine you probably press the button 'xdefl' to make CH2 the X input?.
I agree with Nigel as I don't see an XY or an external Horiz (X) input?
I also suggest you give this a read and start getting an understanding of what the pattern is all about other than an interesting image on a scope. Start working with your scope and getting a handle on oscilloscope basics.
<EDIT>Ah wait a moment, I see it. You use the Exrternal Trigger input. You hit X DEFL and run your X axis into the external trigger BNC. Where it says Trig or X Defl. </EDIT>
Ron
Thanks <blush> yes I realised it'd be a V/V graph ( not V/t ) so. All those triggering switches bottom right of pic. Shall I leave the whole lot 'out' or off ?
I'll fire it all up in a bit see how I get on
Ron
I've got the basics down to a fine art lol. Its the tricky stuff I need a bit of help with :) Cheers for the link though - i've scoured google - cant even find a phillips scope manual to buy, never mind download lol
checked the link. nice math, nothin practical there. even the bottom links are for java pretties n' stuff. I need the real thing >:)
If you see my edit you will see how to set it up. Your Y axis will be a vertical channel and your X axis will be fed into the external trigger BNC. Use the X DEFL button. Rhat should get you going.
Ron
Just dug out my old scope Phillips PM3256 and sig gen.
Look at the image.:)
thats fantastic thanks fellas. I played for ages, switched it all off, checked here, theres the info !
I shall endeavour to apply this info tomorrow evening after work, its a little late here now. Thanks again
As an aside the best 'general' info I could find for understanding lissajous figures after scouring google many times was this fine guide:
Lissajous Figures
regards
Could'nt wait til tonite - I have an hour before work so ...Well thanks to your help I managed to get my lissajous trace - this is a 1khz and 2khz ( approx ) sine waves input.
https://www.youtube.com/watch?v=4bYAzZATVpY
Next query. I cannot get the trace to 'stay still'. Is there anyway I can do that ? Or is it always going to drift about, nice eye candy but unable to study the waveform ?
I think the two signals have to be in phase to get a stable non moving waveform.
YouTube - VID 00006-20100416-0730.3GP
hi.
Look at this pdf, make up the 'shifter circuits.
  • Exp-9..pdf
Thanks again Eric ! I was googling around for phase shift circuits last night without much success but this looks great - and easy ! I shall fire up the soldering iron tonight !
Give me a few minutes and will post a handy little phase shifter circuit.
EDIT:
Look at these images.
φ= 2 * tan^-1* [R3/Xc1]
Where Xc1= 1/[2Π f C1]
The image showing the circuit is with R3=10k and the smaller image with R3=2K
If you can lock the two signal sources to a common reference this would put the phase in line. ie. two sig gens with same external ref.
thanks so much again. I have my 'homework' for the weekend now :D
By the way 54 yr old tech level service engineer here. Great with DC, got me 224's, licenced ham since '87 ( g0ier ) but not so hot with phase shift and AC theory - but enjoying these insights :D
I need a wee drinky first now we've reached the weekend but I will be back !
Ahh. now your tantalising me as a scope newby ! Yes I was using the 1000 Hz ( fixed ) output from my lovely old Heathkit RF Oscillator ( Model IG 5280 ) as sinewave A and a 2 khz sinewave from my shiny new Pintek FG30 sweep gen as Sinewave B.
I just about barely grasp its the initial trigger or measure point that needs 'locking' . I have no idea how to do such a thing. Glad I posted though - learning a heap :)
hi.
hi again :) Up with the larks, I whipped together the passive RC Phase shift network in the link.
I 'matched' the resistors and caps for closest accuracy. The resistors came in about 994 ohms and the C at 112 nF
This was the result:
A nice stable 1:1 lissajous. ( as expected ) My only dissapointment is it is an oval shape rather than full circle. Adjusting the signal amplitude and juggling the volts/div ch1 will not create a perfect circle.
I am clear on what I want to do next thanks to these experiments ( thanks for the assists ). I want to make a sinewave generator with 'multi' frequency outputs.
My first idea was a frequency divider circuit, where I can 'tap' into the frequency divisons. So I might have a 10 MHz oscillator with a frequency divider network giving outputs at 9/8/7 MHz and so on, right down to say 1 MHz.
Is such a circuit feasible ?
oh and ...
EDIT:
View attachment 41688View attachment 41689
This is a really nice easy looking phase shifter circuit thanks eric
regards all
oh and ...
regards all
You are becoming a techno nerd...:)
The problem with the freq divider is that it will be a square wave output.!!
Look up Wien oscillators. , also there are IC's which make good Function generators.
Ref the waveforms,,, turn the Y amp switch CW , so that the trace is oval, with its major axis vertical and then adjust the 'blue' CAL knob on the Y amp until you get a round waveform.
Lets know how it goes...
BTW: always set the CAL knob to CAL when you do any serious measurements.
Use the 1.2V sig cal pin as a quick Y amp check.
Thanks ! I was praying I would'nt be the only one Eric, when I sought a forum, joined and posted my puzzlement ! Looks like you're the answers to my prayers haha!
Interesting. Very interesting. In fact I've been image googling 'frequency dividers' and see there is a dearth of square/pulse wave dividers out there. Dividing sine wave frequencies is another matter entirely by the look of it. But I came across this most interesting sine wave divider circuitry :
**broken link removed**. My initial thought was cobble summat up with mpf102's or 2n2819's and some ceramic resonators I have. But it propbably would'nt work.
The scope's resting at the mo but as soon as I get my next techno-urge I will pay some attention to your CAL button advice, thanks.
Oh Eric - my PM3256 'cal' signal output appears to be 2.33 kHz graticule calculated and 2.35 kHz measured on a Phillips PM6667 freq counter. I sort of expected a 1kHz cal signal. Could you confirm to me the manual quoted value ? ( I reckon it'll be 2.4 kHz )
regards
This is a early version of the function generator IC, I understand they are still around also I believe there is a 'newer' version.
EDIT:
I have/had a manual somewhere!
I will look, but dont hold your breath.
EDIT2:
Unable to find the manual at this time, look at this link, scroll down linked page for a manual
  • XR2206v103.pdf
