Need PIC16F84A Cool Project
On who do your most project ideas depend on?
  • Self
    Votes: 0 0.0%
  • Friend
    Votes: 0 0.0%
  • Teacher - School
    Votes: 0 0.0%
  • Online Search (Somebody else's idea revisited)
    Votes: 0 0.0%
  • Total voters
    0
Duplicate Posts
... I was sure: the browser freezed, I refreshed: I got a couple of similar posts... I think we should get 2 delete at least the similar posts...
Re: Duplicate Posts
Yep, it sucks not be able to delete your own posts :cry:
Re: Duplicate Posts
It's not a problem, as moderator I delete any double posts I notice - as you say, it's VERY easy to accidently double post.
are you thinking of an momory game that has 4 butons and thy keep lighting in a seqence and you have to repeat it.
In that case it wod be more simple to use 4 difrent color LEDs stuck on 4 buttons.
Or are you thinging of a maching game that you have cards and you have to find pairs.
In ether cases you need a way to randomize it.This can be done by drving noise on an I/O pin and trying to reed it evry cuple of time this way you get a seris of random 1s and 0s.
Yes, A memory game: Writing up a sequence of digits (cause my keypad has only digits) and then askin' the user 2 input'em... I just want the functionality of the LCD screen, along with the keypad, not that I'm obliged to use'em...
Oh a nice simple project.
the PIC simply generates an numbr displays it and waits for the user to input it and it displays more an more numbers
LOL I wouldn't like to play such game :shock:
yea i wod rathe make an pong game becose its way more fun.
Or i havent seen a lights out game whith an PIC
That's very refreshing :shock: ! Hehe, I want now the LCD to work!
But I have the 16F84A... Not the 16F628, which Nigel based his tutorials on... I took out the comparator line, from the code, and changed the porta/trisa to portb/trisb (cause it's 8-bits) and it didn't work :cry: :!: :!: :!:
You cod try to use an high level compiler becose you have built in libarys that do it all for you and its much fater to make an program in a high level compiler.
You cod try mikroBasic becose its realy simple
Why did you change the PortB/TrisB, they are the same for 16F84 and 628.
Also, make sure that you have oscilator connected to the PIC, because 84 doesn't have internal oscilator.
Jay, I have an oscillator and everything for the PIC to work: I have previously used it for other programs, so it should be working fine... Now for the PortA/B, I dunno nothing abt the 628, but It looks like it has an 8-Bit PortA, or my 84 just has 5-bits for porta...
And the 84 has 8-Bits for PortB... That's y I made the change... Still, the LCD is justflashing up blocks of 'liquid crystal', and no characters or anything whatsoever... :?
OK, that's true. I though you also changed PortB, which is the same for both PICs. You did well with PortA though.
Do you see both lines with dark blocks?
