mic preamp opamp working only on a single supply
Your problem:
At R1 <1K, you are getting a gain > 101. With 100K source impedance for the input bias current to the non-inverting input of the opamp, and <1K source impedance for the input bias current to the inverting input of the opamp, the bias current causes a differential DC voltage between the inputs, which is amplified by the gain (>101), which causes the output level of the opamp to shift so far that the audio signal is clipped.
Set R1 to get a gain of about 200. With no mic input, measure the DC voltage at the output pin of the opamp. I'll bet that it sits very close to the positive supply voltage.
If you really think you need gains exceeding 100, then use two opamp stages, one with a gain of 10 followed by a second one with a gain of 10 to 50.
What Opamp are you using?
i m using 4558
and yes it was close to the positive supply voltage
i m not looking for gain here, i m looking for the use of mic between the op amp dual supply vs the single supply
i checked now to be sure again and in the single supply opamp ,there was no clipping in max gain and no distortion at all.
btw same power supply 8.1v for single and for the dual supply 4.05+/-v
The 558 has rather large input bias currents, so will be greatly affected by unbalanced input resistances...
In the single supply version you posted originally, the resistances at the inputs were almost perfectly balanced. In the split-supply circuit, you have 100K in one input and <1K in the other, which is causing it to rail. Replace the 100K with 10K or less, and that will fix the bias problem, but might load the electret too much...
i've tried with a variable resistor to switch the resistors in the positive input and try different values but the situation stayed the same
If you use an opamp with Jfet inputs like a TL071 then the input bias current is extremely low leakage current. The gain of 200 times the extremely low leakage current equals almost no output offset voltage.
Using an ordinary opamp with the single supply circuit then the resistor to ground part of the negative feedback can have a polarized electrolytic capacitor to ground in series with it. Then the input offset current is not amplified. With the dual-polarity supply circuit then the capacitor to ground must be a non-polar film type.
Using an ordinary opamp with the single supply circuit then the resistor to ground part of the negative feedback can have a polarized electrolytic capacitor to ground in series with it. Then the input offset current is not amplified...
Just like the circuit in Post #8 of this thread.
i 've tried it polar and non ploar
A polarized electrolytic capacitor usually has a DC voltage across it. With a dual-polarity supply the DC voltage of the capacitor we are talking about will be small and you do not know its polarity so you might install it backwards.
I have seen equipment with non-polar electrolytic capacitors. These capacitors are smaller and much less expensive than non-polar film capacitors.
one of many caps i used
You used huge 300V capacitors made for old vacuum tube circuits.
I have some 1uF/63V film capacitors with the pins 0.2" (5mm) apart and they are fairly small.
no you miss understood it was just an example of a type of cap i was using,i 've tried many tapess and sizes it's not it.
the hell with that circuit
