Half way done and wish I had made a PCboard
I have posted nearly every detail you need here in this thread.
Please, please, please follow what I have posted here. I'm not posting here because I has nothing else to do. Post #52 covers the Dim statements.
The stuff you're reading at Digital-DIY is a different project, different day and does things differently. If you read the include statements, there's an AS1106 module included. That is used for 7-segment displays with decode. You're not using a 7-segment display here are you?
If you think I haven't addressed a point, READ AGAIN. It's more likely ou missed it than I did.d
After studying your post about a different project I get the drift of differences.
Am in process of rewriting my code as per your suggestions.
I get to wandering and wondering alot. I ask too many wHAT IF
I have given you ALL OF THE BASICS RIGHT HERE. Please just try it exactly the way I've laid it out before you start "experimenting" or trying to "fix" something. There are an infinite number of ways to screw this up – you don't need to prove that right now.
Just do it as I've laid it out, describe the pattern here in enough words that an idiot will be able to understand exactly what you get. Then and only then try this test: make the outer square of LEDs illuminate....and post the code. Then you'll on your own. Actually, until you post the code to do that, I'm done.
Making lots of progress AFTER I looked over everything and just by chance I discovered the matrix in in backwards as per picture.Arduino - ShiftOut. The pcboard is marked w/ LED1 on one side but the square mounting hole is on the other side. Turned matrix around and I now have a working matrix. Now to make a square as Jon suggested.
*  Name    : UNTITLED.BAS                                                   *
*  Author  : [select VIEW...EDITOR OPTIONS]                                 *
*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS]              *
*          : All Rights Reserved                                            *
*  Date    : 8/4/2014                                                       *
*  Version : 1.0                                                            *
*  Notes   :  new revision by starting over and addressing the registers.                                                              *
DEVICE = 18F2420
CLOCK = 20
INCLUDE "shift.bas"
INCLUDE "utils.bas"
INCLUDE "convert.bas"
   ' INCLUDE "DS18B20.bas"
INCLUDE "Utils.bas"
include "convert.bas"
//PIN DESCRIPTION
DIM Load_pin  AS PORTC.5   // LATCH
DIM Data_pin AS PORTC.4    // DATA
DIM Clock_pin AS PORTC.3   // CLOCK
//DIM X AS BYTE
//DIM index AS WORD
DIM Display_Reg AS BYTE     //register settings
DIM Display_Data AS BYTE    // Data to be displayed
DIM Data_out AS WORD        // Data for additional matrix (4)
                     // define max7219 registers
byte max7219_reg_noop        = 0x00;
byte max7219_reg_digit0      = 0x01;
byte max7219_reg_digit1      = 0x02;
byte max7219_reg_digit2      = 0x03;
byte max7219_reg_digit3      = 0x04;
byte max7219_reg_digit4      = 0x05;
byte max7219_reg_digit5      = 0x06;
byte max7219_reg_digit6      = 0x07;
byte max7219_reg_digit7      = 0x08;
byte max7219_reg_decodeMode  = 0x09;
byte max7219_reg_intensity   = 0x0a;
byte max7219_reg_scanLimit   = 0x0b;
byte max7219_reg_shutdown    = 0x0c;
byte max7219_reg_displayTest = 0x0f;
//DIM Options(16) AS BYTE
//DIM I AS WORD
SUB Write_Matrix ()
        Load_pin = 0
        Data_out =256*Display_Reg+ Display_Data
        shift.out (MSB_first,Data_out,16)
        Load_pin =1
END SUB
PUBLIC SUB InitLed()
       Display_Reg = 9    // decode
       Display_Data = 0  //all
    Write_Matrix        // write to matrix
       Display_Reg = 10    //intensity
       Display_Data = 15   //max
    Write_Matrix
       Display_Reg = 11    //scan limit
       Display_Data = 2
    Write_Matrix
       Display_Reg = 12    //shut down
       Display_Data = 1
    Write_Matrix
END SUB
PUBLIC SUB clear_display()
           DIM I AS INTEGER
           FOR I = 1 TO 3
           Display_Reg = I
           Display_Data = 0
           Write_Matrix
       NEXT
END SUB
public sub TestMode(Test as boolean)
       if test = true then
          Display_data = 1
          Display_reg = %1111
          write_matrix
        else
          Display_data = 0
          Display_reg = %1111
          write_matrix
        end if
   end sub
// PROGRAM CODE SET UP
setalldigital
shift.setoutput(Data_pin)
shift.setclock(clock_pin)
output(load_pin)
load_pin = 0
InitLed
  Display_data = 1
          Display_reg = %1111
          write_matrix
        delayms(500)
          Display_data = 0
          Display_reg = %1111
          write_matrix
//InitLED 'sets up the registers
WHILE 1 = 1
Display_Reg  = 1
Display_Data = %11111111
Write_Matrix
Display_Reg  = 2
Display_Data = %00000111
Write_Matrix
Display_Reg  = 3
Display_Data = %00000100
Write_Matrix
Display_Reg  = 4
Display_Data= %00001000
Write_Matrix
Display_Reg = 5
Display_Data = %00010000
Write_Matrix
Display_Reg  = 6
Display_Data= %00100000
Write_Matrix
Display_Reg = 7
Display_Data = %01000000
Write_Matrix
Display_Reg  = 8
Display_Data= %10000000
Write_Matrix
DELAYMS(1000)
clear_display
DELAYMS(1000)
WEND
Why in the Init routine is the scan limit set to 2? What should it be set to?
Why in the clear_display routine is I = 3? What should it be?
You got creative in the program loop. Clearly, what you're seeing is not what I intended. Why are you seeing what you're seeing, and why don't all the columns illuminate?
I copied the code using select all but I guess It didn't paste what I wanted.
I changed to 7 because there are 8 leds.
we have 8 leds to clear out. I tried with original suggested settings and only some of the leds lit up. Only the first 3 colums.
here is the code with a colum scrolling from left to right. Amazing what happens when the matrix is put in correctly, not as per pcboard silkscreen. Have to change the scan limit for number of Max7219/matrix displays but first to get a letter to scroll using a const array??
DEVICE = 18F2420
CLOCK = 20
INCLUDE "shift.bas"
INCLUDE "utils.bas"
INCLUDE "Utils.bas"
//PIN DESCRIPTION
DIM X AS BYTE
//DIM index AS WORD
//DIM I AS WORD
SUB Write_Matrix ()
        Load_pin = 0
        Load_pin =1
END SUB
       Display_Data = 8   //max
    Write_Matrix
       Display_Data = 7    // to scan entire matrix
    Write_Matrix
       Display_Data = 1
    Write_Matrix
END SUB
           DIM I AS INTEGER
           FOR I = 1 TO 8        // for 8 colums
           Display_Reg = I
           Display_Data = 0
           Write_Matrix
       NEXT
END SUB
       if test = true then
          Display_data = 1
          Display_reg = %1111
          write_matrix
        else
          Display_data = 0
          Display_reg = %1111
          write_matrix
        end if
   end sub
setalldigital
output(load_pin)
load_pin = 0
InitLed
  Display_data = 1
          Display_reg = %1111
          write_matrix
        delayms(500)
          Display_data = 0
          Display_reg = %1111
          write_matrix
WHILE 1 = 1
for x = 1 to 8
Display_Reg  = x
Write_Matrix
delayms(500)
DELAYMS(10)
clear_display
DELAYMS(10)
next
WEND
The scan limit has nothing to do with adding additional MAX7219 boards in a string with the first. Better go back and read the data sheet.
To use multiple MAX7219s, you'll have to shift out 16 bits for each chip (i.e., 32 bits for 2 chips, 48 for 3...) before strobing the latch.
The multi-matrix board controlled by an HT1632C I recommended probably would be easier to use instead of several of the MAX7219 boards strung together. If I'm reading the description correctly, you'll have to rotate the boards so the "columns" are horizontal to position them side-by-side. It's do-able, but it's seriously going to complicate scrolling.
I realize the scan limit has nothing to do with multiple boards. When I had the limit set to 3 I could only enable the first 3 colums of leds. Changed to 7 and I can enable all 8 leds across.
Going to have a look at the HT1632C but ordering anything at this point in time until after Sept 1st. is iffy to receive as we are in process of moving last week of August.
In fact we are headed your way and I hope to buy you lunch or dinner after we get settled in.
Moving to Ryderwood Wa.
.... Have to change the scan limit for number of Max7219/matrix displays.....
Oh, perhaps I misunderstood exactly what you wrote?
No....your new place is quite far away from me still.
Yea it is kinda about 100+ miles but I want to go back to the Space Needle for dinner and visit the Lasizerium again. We were there about 10+ years ago and they had THE WALL.
Would like to go to the science museum as well.
Took a brief look at the HT1632C, pretty awesome chip to drive several matrices.
Need to wait until after I move to purchase any more stuff. Thinking about a couple more Tap 28 boards if they are still available.
MrDEB has decide to continue this conversation on the Swordfish Basic forum, but apparently forgot to go back and see if anybody replied. It's really kind of bad form to ask the same question in multiple forums.
I didn't forget, I visited the Swordfish forum several times today in between internet going down.
I got a letter to scroll across one matrix but getting a second to display correctly.
Going back to one matrix and see if I can get the code slimmed down into a simple 15 lines of code or less to display desired text.
Experimented with two max7219's and one colum of leds but to no avail yet.
Going to look at the "easier" to understand data sheet and maybe??
If I can't get it working by Saturday its time to pack this project up for moving .
After looking at page 12 for the as1106 I see where I need to address the no-op reg several times as per number of matrixes.
No. Data is latched into the MAX7219 when the latch line is strobed.
Instead of shifting out 16 bits for the single MAX7219 and strobing the latch, you shift out 16 bits of data for each one in the string, with the data destined for the furthest one shifted out first. Then strobe the latch line to latch the data into all of them at the same time.
The Dout pin of the first matrix goes to the Din pin of the second and so on.
If you use exactly the code I have above with no changes, the character on the first matrix will appear on the following matrices, one step behind.
I realize the above means nothing to MrDEB.
Lets say you have 3 Max7219s in series, Dout to Din....
Change
To
shift.out (MSB_first,Data_out3, Data_out2, Data_out1, 48)
You'll have to revise the Write_LED routine a little.
I changed code to post 51 but a no go
referring to the as1106 data sheet page 12 it says the no-op reg to be addressed after each write? this seemed to help but it makes sense to use shift.out (MSB_first,Data_out3, Data_out2, Data_out1, 48)
going to change as per post 75
too many parameters
  shift.out (MSB_first,Data_out1,data_out2,32)
if I use 16 its ok. I realize maybe 32 bits but dosen't the first 16 bits just migrate into the second matrix?? Seems like that's what it should do??
I got both matrixes displaying the same thing when I use the no-op register setting.
Ok, the shift routine can handle a maximum of 32 bits, so you could shift data for two of the MAX7219s at a time. Since you're using more than two, just stick to the no-op codes.
Realize if you shift data into the first MAX7219, you'll have to "flush it out" by shifting it past each additional MAX7219 without strobing the latch line.
A string of matrices driven by MAX7219s is not ideal for scrolling text using any method I can see at the moment.
Don't say I've never done anything for you. Here's a revised WriteLED subroutine that handles the no-ops for you. Sorry, the code formatting didn't survive copying.
To use it, define LED_Data and LED_Reg and then
WriteLED(x) where x is the unit number from 1 to 4. Unit 1 is the first in the string.
Sub WriteLED ()
  LoadPin = 0
  Data_Out = 256*LED_Reg + LED_Data
  Shift.Out (MSB_FIRST, Data_Out, 16)
  LoadPin = 1
End Sub
Sub WriteLED (Unit As Byte)
  'This subroutine supports 4 MAX7219s in series
  'Unit 1 is the first in the string, 4 is the last
  LoadPin = 0
  Select unit
  Case = 1
  data_out = 256* 0 + LED_Data ' no op
  Shift.Out (MSB_FIRST, Data_Out, 16)  'no op unit 4
  Shift.Out (MSB_FIRST, Data_Out, 16)  'no op unit 3
  Shift.Out (MSB_FIRST, Data_Out, 16)  'no op unit 2
  Data_Out = 256*LED_Reg + LED_Data  'data to unit 1
  Case = 2
  Data_Out = 256*LED_Reg + LED_Data  'data to unit 2
  Shift.Out (MSB_FIRST, Data_Out, 16)  'no op unit 1
  Case = 3
  Data_Out = 256*LED_Reg + LED_Data  'data to unit 3
  Case = 4
  Data_Out = 256*LED_Reg + LED_Data  'data to unit 4
  End Select
  LoadPin = 1
End Sub
I started going in that direction of addressing each matrix as itself but wasn't sure so I didn't go any futher but perhaps I should have.
I call it GETTING FRUSTRATED
But with all I have on my plate I think I am going bonkers.
Worrying about the house in Washington getting the required repairs by Aug 27th and throw in the appraisal, hope escrow closes before we leave Idaho. If not well I guess we are homeless for a few days.
As I revise code I think back to all the help you Jon in particular have given me.
Now to go write in the new WRITE_matrix routine. I printed it out first so I can make required revisions to suit my DIM statements etc.
