Posting a two page schematic
MrDEB
I use Diptrace to produce schematics but posting has been an issue due to readability.
Is there a better method to posting a schematic than using PAINT?
PAINT-screen shot-copy area desired then save as a png file.
have seen schematics where a magnifying glass appears then click on to enlarge. Or how to convert to a PDF??
Do you have the "Snipping tool" (Window's Vista and later)?
Use a freeware tool such as PDFCreator, which emulates a printer.
The snipping tool is similar to the "print Screen" key, except that you can control the extent (portion of the screen) you copy, its name and the file type (jpeg, gif, etc) you save it as. Makes it very easy to upload to ETO.
hi Deb,
This is a free useful tool.
E.
Lets try this method using photobucket.
Here is the two page schematic of my hearing aid that Audioguru helped me with the design. I purchased all the parts but before ordering a board I want to double check my schematic. Its all smd
it has two front mics and two rear mics. If you have ever worn hearing aids you will realize that they amplify EVERYTHING so having a conservation in a noisy environment is imposable unless you can turn off the rear mics.
feel free to use if you need a cheap ($50) hearing aid instead of say $5000 per pair. My issue is the average hearing aid has a life expectancy oif 2.7 years. At $5000 it is a questionable purchase but a must buy, I plan to use this hearing device only while in the shop or cooking at the county fair (heavy sweat conditions)
Hi Mr. DEB,
1) You forgot to bias pin 3 of the quad opamp like I showed in April and its coupling capacitor value is much too high if the bias resistors are 100k each.
2) I can't read the part numbers on your schematic. The value of 10uF for C28(?) is much too high. It was 0.01uF in April.
3) The mic has a single 2.2k bias resistor in April but now it is two resistors.
4) The original tone controls circuit uses a 500k pot for treble (the one on the right side of your schematic).
THANKS I have made so many schematic revisions that some items slipped by.
I though I had it all corrected but??
corrections made
I see where I messed up/got lost
I need to check if I ordered the 500k pots smd. as well as the 2.2k resistors.
Forgot to ask, do you want a couple of these boards. Can get three made for the same price as 10
found another mis connection it was late
I discovered early this morning that I had the inverting inputs connected to bias and not grd via R6/C12 and R13, C16
will research futher later today as I have a full plate this morning.
QUESTION are these schematics easier to read using PHOTOBUCKET?
I can't read your fuzzy schematic so I don't know what you are talking about.
No.
Photobucket takes all day to wake up and the schematic will look the same.
Your schematic is too small and the parts are too far apart. The text looks jagged and too small.
here is an input section
Hopefully readable unless I compress and send a file but the schematic is in DIPTRACE format
Your new schematic is readable (when we click on it to enlarge it) but then it is too big. It is covered in DOTS.
Its parts are still too far apart.
Why aren't R11 and R12 in line with each other?
I thought that spread out would be easier to read but I am wrong.
Will crunch it all together closer.
I see I can export the file in DXF or P-CAD ascii
not sure what they are???
Why in the hell don't you follow advice given to you. Alec_T mentioned PDF Creator. PrimoPDF is a similar free tool. Install one of these, they you just print your schematic, selecting whichever one you install as the printer. You have to attach the pdf as a file but it will have the same resolution as your printout would...and freedom from "all the dots" that Audio Guru complains about.
Don't get me wrong, I think Audio Guru is a saint for explaining the same things over and over and over again!
I tried downloading PDF creator but it didn't seem to work right.
Will try it again. Maybe I downloaded something other than PDF CREATOR
PrimoPDF is one I haven't tried.
