madderscience
Hi all-
I'm relatively new to PIC processors, and like some previous posters I am building what is essentially a voltmeter (eventually to become part of a data acquisition system for my electric car).
However the problem I seem to be having doesn't match what is described anywhere else I can find on this forum, so I'll post this and let you guys tell me what presumably dumb thing I am doing.
My problem is that after finishing an ADC sample cycle, I cannot get ADRESL to read back anything other than Zero. However I am getting sane values from ADRESH. If I left justify the adc results, I get 8 bits of good data from ADRESH, but always zero from ADRESL. If I right justify the results, I get two bits of good data from ADRESH, but ADRESL still reads zero. Yes, I am using bank bits. I am transmitting my results off of the PIC via rs232 on an unused pin, so I can see what I am getting on a remote computer terminal.
Here are the (relevant) portions of my code: (comments may be truncated)
one-time-setup:
InitIO BANKSEL GPIO ; select bank containing GPIO (bank 0)
clrf GPIO ; clear contents of GPIO
clrf CMCON0 ; CMCON0 set GP0, GP1 to analog input, GP2 to I/O and
BANKSEL ANSEL ; select bank containing ANSEL register (bank 1)
movlw 0x33 ; set up ADC for dedicated clock and input on AN0
movwf ANSEL ; and write to ANSEL register.
movlw 0x03 ; set up tristate control buffer for input on GP0 and GP1
movwf TRISIO ; GP5,4,2 all outputs. GP3 is always a
BANKSEL GPIO ; go back to bank 0
return
sample routine, called periodically:
(ADCON0 is set to 0x0 before calling (Vdd reference, left justify, channel zero), the "Delay" routine sets up a variable duration watchdog timer wake-from-sleep based on the contents of W, and is known working)
Sample bsf ADCON0, 0 ; turn on adc.
movlw 0x0
call Delay ; wait 1/8s (way longer) than acquisition tim
bsf ADCON0, 1 ; GO!
btfsc ADCON0, 1 ; are we really done???
goto $-1
; store the result in program memory.
movfw ADRESH
movwf sampleH ; <<<< WORKS FINE, GETTING SANE DATA
BANKSEL ADRESL
movfw ADRESL
movwf sampleL ; <<<< ALWAYS ZERO!! GRRR!!!!!!
BANKSEL PIR1
bcf ADCON0, 0 ; turn off adc. isr should have done this, but
return ; and done,
I can do without the two least significant bits, but I'd like to have them if possible.
Thanks to all.
Brian
one-time-setup:
return
movlw 0x0
bsf ADCON0, 1 ; GO!
goto $-1
movfw ADRESH
BANKSEL ADRESL
movfw ADRESL
BANKSEL PIR1
return ; and done,
Thanks to all.
Brian
