How did you test the outputs?While testing the PWM chip I find that both the outputs are in phase instead of 180 degree out of phase.
No. They are driven out of phase. If you're seeing them in phase then check for a short-circuit between them.Is my understanding about the outputs to be out phase wrong?
That was what I was thinking when I asked earlier what Badal was using.I suspect that your scope triggering is set to alternate trigger.
Sorry Jim.That was what I was thinking when I asked earlier what Badal was using. JimB
It is normally the other way around Ron.Spec can type faster than I can. I also want to blame it on scope triggering.
