What type of capacitor are these?
antknee
I can only reliably identify two different types of capacitor, electrolytic and ceramic. I have two other capacitors that I need to identify. Which type are these?
The first is orange and measures on an LCR meter at 0.1uF. It is marked:-
.1K
DC 100V
EM7/TSC
The second is deep red and measures on an LCR meter at 47nF. It is marked:-
.047K..
DC 100V
PEE/TSC
Thanks,
Antknee
.1K
DC 100V
EM7/TSC
.047K..
DC 100V
PEE/TSC
Thanks,
Antknee
They are clearly marked as they tested 0.1uF (.1K) and 0.047uF (.047K).
They do look like polyester film. Also they are for use in a high frequency board, around 1.6MHz. Polyproylene is often used at these frequencies, I believe, and they look similar too. Hmmm.
Can someone identify this Cap? it's 10uf, I think it is polarity sensitive, but would like to be able to look it up.
It's a tantalum. It will have 106 and it will have the voltage on it: 16v, 35v etc
Thank you, I assume the upside down L points to the positive lead.
The value is in pF, the last digit is the number or zeros to append to the preceding digits, 106 = 10,000,000pF = 10μF.
Usually the mark is the negative lead.
So do I have this photo labeled correctly or NOT?
106 is 10uf
+25 would be the working voltage -or- + lead and 25 volt???
I believe it's an M after the 25 and I can see no other markings.
When I charge it up and measure the voltage with my DVM, the voltage decays slowly if I charge it as marked in photo, If I reverse it, it decays much quicker.
Thanks,
Kinarfi
Wow, exactly the opposite of aluminum electrolytics. EDIT: Well, radial leads at least. Don't know SMD markings. Why would they do that?
I hate these kinds of things.
That's why you have to be so intelligent to be an electronics designer. Anyone can be a Lawyer but very few can qualify at electronics.
I have never thought that these caps have a polarity !! Thanks colin55.
this is the beauty of Electro Tech ONLINE
Not only is the polarity very important but a tantalum capacitor suffers from a problem of going "short-circuit" if it sees a spike.
This type of capacitor was always going "short" in Luxor TV's. It was a very good "money earner."
Thanks Colin55, excellent post, just the info I needed.
Kinarfi
