How come the numerator is C1R2?Because the op amp's output impedance is low and its impedance at both inputs is very high, deriving the transfer function of the Wien network (the resistive divider made up of R1 and C1 on the top and R2 and C2 on the bottom) is relatively straightforward. Thus, the transfer function is: **broken link removed**
Where j represents a 90-degree phase shift in the transfer function (either positive or negative). The other (non "j") terms represent zero phase shift in the transfer function. As the magnitude of the terms change, the resultant phase shift also changes. Equation 1 shows that the "non-j" terms in the denominator equate to zero, leaving only j terms in the numerator and denominator.
Yeah.Nigel Goodwin said:Use a small lighbulb to stabilise the oscillator.
audioguru said:Yeah.
Bounce, bounce, bounce, bounce, bounce, bounce, bounce, bounce, bounce, ...![]()
bananasiong said:The resistance of the bulb keeps changing due to the AC signal?
