birdman0_o
Active Member
Just wondering if anybody has any experience with this chip, spent hours yesterday and couldn't get the sine test to work
Thanks!
Thanks!
void Write_MP3_Data(Uint32 *buffer, Uint8 count)
Uint8 i;
Init_SPI_1(MP3_Data); //settings were described above
MP3_DCS_OUT_ = 0; // tell the chip we're sending MP3 data
for (i = 0; i < count; i++)
SPI1BUF = *buffer; // Send 4 bytes... we're sending Uint32's here!
while (!SPI1STATbits.SPIRBF && !MP3_DCS_OUT_);
MP3_DCS_OUT_ = 1;
// Service_MP3_Audio() was called from main every 50mS
void Service_MP3_Audio( void )
static vs1011_state_type vs1011_state = VS1011_INIT;
static Int32 bytes_remaining;
static Uint32* pData;
Uint8 buffer[4];
switch (vs1011_state)
case VS1011_IDLE:
if (app_status.play_click)
vs1011_state = VS1011_PLAYING_SOUND;
bytes_remaining = SOUND_CLICK_LENGTH;
pData = (Uint32*)sound_click;
app_status.play_click = 0;
else if (app_status.play_sound28)
bytes_remaining = SOUND_28_LENGTH;
pData = (Uint32*)sound_28;
app_status.play_sound28 = 0;
break;
case VS1011_PLAYING_SOUND:
// if MP3_DREQ_IN is high, then at LEAST 32 bytes
// of data are free in the VS1011
while (MP3_DREQ_IN && bytes_remaining > 0)
// Get the byte ordering correct!
buffer[0] = (Uint8)(*pData>>24);
buffer[1] = (Uint8)(*pData>>16);
buffer[2] = (Uint8)(*pData>>8);
buffer[3] = (Uint8)(*pData>>0);
Write_MP3_Data( (Uint32*)buffer, 1 );
pData++;
bytes_remaining -= 4;
if (bytes_remaining <= 0)
vs1011_state = VS1011_IDLE;
break;
#include "sounds.h"
const Uint8 sound_click[] __attribute__((aligned(4))) = {
0x49, 0x44, 0x33, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x54, 0x43, 0x4F,
0x4E, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x42, 0x6C, 0x75, 0x65, 0x73,
0xFF, 0xF2, 0x84, 0x00, 0xE1, 0x18, 0x00, 0x00, 0x00, 0x01, 0xA4, 0x00, 0xA0,
0x00, 0x00, 0x11, 0xF9, 0x7E, 0xA8, 0x03, 0x43, 0x18, 0x00, 0x60, 0x18, 0xBD,
0x11, 0x11, 0x11, 0xDD, 0xDD, 0xDD, 0xCF, 0x7F, 0x88, 0x88, 0x9C, 0xFA, 0xEE,
0xE7, 0xBB, 0xBB, 0xE8, 0x89, 0xA0, 0x00, 0x00, 0x00, 0x87, 0x03, 0x03, 0x30,
0xE2, 0xDF, 0xFF, 0xE2, 0x7D, 0x77, 0x7E, 0xBB, 0xBB, 0x9F, 0x11, 0xC3, 0x81,
0x81, 0xBC, 0x44, 0xC2, 0x00, 0x00, 0x00, 0x08, 0x01, 0x87, 0xD6, 0x0F, 0x87,
0xF5, 0x02, 0x1E, 0x0F, 0x9F, 0x2E, 0xFE, 0x0F, 0x83, 0xEF, 0xE0, 0x81, 0xCF,
0xFC, 0x1F, 0x07, 0xDE, 0xC0, 0x60, 0x30, 0x18, 0x0C, 0x06, 0x03, 0x01, 0x80,
0xC0, 0x60, 0x30, 0x18, 0x00, 0x3F, 0xE0, 0x03, 0x66, 0xF0, 0xF4, 0x80, 0xA0,
0x1F, 0x12, 0xE1, 0x3C, 0x78, 0x26, 0x18, 0x51, 0x83, 0xFB, 0xF8, 0x84, 0x21,
0x76, 0x85, 0xF2, 0x12, 0x5F, 0xF0, 0x1E, 0x50, 0x0D, 0x0B, 0x10, 0x37, 0xB0,
0x80, 0xDE, 0x61, 0x03, 0x02, 0xB3, 0xFF, 0x00, 0x63, 0x41, 0x70, 0x82, 0x7B,
0x14, 0x10, 0x18, 0x60, 0x20, 0x98, 0x8F, 0xFF, 0x0F, 0x98, 0x0C, 0x80, 0x20,
0x0A, 0x56, 0x00, 0x08, 0xC0, 0xC2, 0xC0, 0x03, 0x22, 0xDC, 0x0D, 0x9A, 0x8F,
0xFF, 0xC0, 0xD4, 0x33, 0x04, 0x85, 0x01, 0x8A, 0x06, 0x0D, 0xFF, 0xF2, 0x84,
0x00, 0xD8, 0x78, 0x61, 0x00, 0x00, 0x01, 0xA4, 0x00, 0xC0, 0x00, 0x00, 0x2B,
0x33, 0x6F, 0x2A, 0x5F, 0x94, 0xA2, 0x03, 0xF8, 0xA6, 0x03, 0xC0, 0x04, 0x43,
0x87, 0xC0, 0x18, 0xFF, 0xFF, 0xFE, 0x54, 0x0F, 0xD8, 0x47, 0x41, 0xE9, 0x85,
0xF0, 0x10, 0x54, 0x2C, 0xF0, 0x64, 0x70, 0xF8, 0x85, 0xF8, 0xE1, 0x22, 0xFF,
0xFF, 0xFF, 0xE3, 0xA4, 0x5C, 0x88, 0x09, 0x44, 0x48, 0x08, 0xD1, 0x43, 0x0C,
0x98, 0xB9, 0x88, 0xE1, 0xFC, 0x9C, 0x2F, 0x93, 0x08, 0x17, 0xFF, 0xFF, 0xFF,
0xFF, 0xC9, 0xC2, 0xA1, 0xD2, 0xF4, 0x90, 0x76, 0x24, 0x8C, 0x0D, 0xCB, 0xC4,
0xD9, 0x34, 0x68, 0x05, 0x06, 0x06, 0x6E, 0xF5, 0xAB, 0x6E, 0x49, 0x54, 0x04,
0x04, 0x4A, 0xAA, 0xAB, 0x33, 0x33, 0x33, 0x37, 0xAA, 0xAA, 0xAA, 0xA9, 0x75,
0x54, 0xB6, 0x66, 0x2F, 0xFE, 0x33, 0x17, 0x18, 0xFA, 0xAA, 0xDF, 0xFC, 0x66,
0x5F, 0xFF, 0xF8, 0xCC, 0xCD, 0xEA, 0xBA, 0xAA, 0xAF, 0xFE, 0xCC, 0xC7, 0xFF,
0x55, 0x55, 0x55, 0x7E, 0x33, 0x33, 0x33, 0x06, 0x02, 0x50, 0x55, 0xD9, 0x60,
0x68, 0x1A, 0x0E, 0xF0, 0x54, 0x15, 0x06, 0x81, 0xA3, 0xDC, 0x4A, 0x0A, 0x82,
0xB8, 0x34, 0x7A, 0x25, 0x05, 0x41, 0x57, 0x60, 0xD3, 0xE0, 0xAB, 0xBE, 0x54,
0x37, 0xA8, 0x1A, 0x0D, 0x78, 0x34, 0x0D, 0xFF, 0xF2, 0x84, 0x00, 0x29, 0x9F,
0x5D, 0x00, 0x00, 0x01, 0xA4, 0x00, 0xE0, 0x00, 0x00, 0x1A, 0x69, 0xDA, 0xAD,
0x97, 0xC3, 0x18, 0x02, 0x3F, 0x12, 0x82, 0xA0, 0xA8, 0x2C, 0xF9, 0x60, 0x68,
0x35, 0x82, 0xA0, 0xB5, 0x4C, 0x41, 0x4D, 0x45, 0x33, 0x2E, 0x39, 0x38, 0x2E,
0x32, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55,
0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55,
0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x4C, 0x41, 0x4D, 0x45,
0x33, 0x2E, 0x39, 0x38, 0x2E, 0x32, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55,
0x55, 0x55, 0x55, 0x55, 0xFF, 0xF2, 0x84, 0x00, 0xD0, 0x26, 0x9C, 0x00, 0x00,
0x01, 0xA4, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x48, 0x00, 0x00, 0x00,
0x00, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55,
0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x4C, 0x41, 0x4D, 0x45, 0x33, 0x2E, 0x39,
0x38, 0x2E, 0x32, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55,
0x55, 0xFF, 0xF2, 0x84, 0x00, 0x1D, 0x9F, 0xFF, 0x00, 0x00, 0x01, 0xA4, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x48, 0x00, 0x00, 0x00, 0x00, 0x55, 0x55,
0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55 };
/*** End of File ***/
/* **** Global Definitions **** */
#define SOUND_28_LENGTH 0x5660
#define SOUND_CLICK_LENGTH 0x03D0
/* **** Gobal Function Prototypes **** */
/* **** Global Variables **** */
extern const Uint8 sound_28[];
extern const Uint8 sound_click[];
void SPIPutChar(char c){
MP3_SPI_IF = 0;
MP3_SPIBUF = c; // write command
while(!MP3_SPI_IF);
MP3_SPI_IF = 0;
Uint16 Read_Adc( void )
Uint16 value = 0;
cs_adc_pin = 0; // Select the ADC
Delay_Microseconds(1);
// Using the SPI, read two bytes from the ADC
SPI1BUF = 0; // Transmit
while (SPI1STATbits.SPIRBF == 0); // Wait for the high byte to be received
value = SPI1BUF<<8; // Read the high byte
while (SPI1STATbits.SPIRBF == 0); // Wait for the low byte to be received
value |= (Uint8)SPI1BUF; // Read the low byte
cs_adc_pin = 1; // Deselect the ADC
return value;
RPOR11bits.RP23R = 8; // SPI1 clock is on RP23
RPOR11bits.RP22R = 7; // SPI1 data output is on RP22
RPINR20bits.SDI1R = 24; // SPI1 data input is on RP24
SPI1CONbits.DISSDO = 1; // SDO not controlled by the module
SPI1STATbits.SPISIDL = 1; // Do not operate SPI while idle
SPI1CONbits.MSTEN = 1; // Enable master mode
SPI1CONbits.SPRE = 4; // Secondary prescale 4:1
SPI1CONbits.PPRE = 0; // Primary prescale 16:1
SPI1CONbits.CKE = 1; // Serial output changes on clk transition from active to idle
SPI1CONbits.CKP = 0; // Idle state for clk is low
SPI1STATbits.SPIROV = 0; // Clear receive overflow flag
// SPI1STATbits.SISEL = 5; // Generate interrupt when transmit is complete
SPI1STATbits.SPIEN = 1; // Enable SPI1
