See post #32 GB.One thing that I've thought of but haven't tried yet is using an LM337 to provide the -1.25 V reference so the LM317 can go down to zero, two diodes would be cheaper, however I do happen to have a few LM337.
spec
Sounds like you have built power supplies before. LOLsystem difficult to stabilize in the frequency domain
Most of the internet schematics have temperature instability and add too much voltage gain to the loop.
My circuit is not the best at temperature. (Vref + Vb-e) But many internet examples are (3 X Vb-e)
For those why don't know what we are talking about:
When look at a unknown voltage, The circuit on the left is more of a voltage comparitor than a amplifier.
If the input is less than the Base to Emitter voltage times 3 then the transistor is off. More than = on.
We all know the Bbe varies with temperature. The voltage gain of the transistor and phase shift adds confusion to the IC.
The circuit on the right also has a Vbe in it but not 3 X Vbe.
If the two resistors have the same value.....
The input voltage-Vbe is on the bottom resistor and across the top resistor.
We are comparing Voltage-Vbe to the temp stable Vref inside the IC.
There is no voltage gain and little phase shift to confuse the IC.
See post #32 GB.
spec
Hope you didn't think I was stealing your thunder!
Yes that is the fiddly bit.You have taken the idea a step further in providing a means of ironing out any variations in the 1V25 references of the LM317 & LM337, I like this!
This is the approach used on many power supplies. With a transformer/bridge rectifier/ reservoir capacitor arrangement, multiple taps on the transformer are used and, often, you can hear the relays clicking in and out as you change ranges. The other approach is to have a range selector switch that selects different taps on the transformer.To avoid any issues with temperature or frequency instability I was thinking that the pre regulator could be just switched in or out by a relay, say at around 15 Volts output. Such that for outputs < 15 V the preregulator could drop the 32V input down to 18 volts. Above 15 volts output the 32V would be fed directly to the lm317 circuit. Given that the maximum current the PSU will provide is around 500mA, the inefficiency won't be a massive issue.
Or even just having fun with electronics.BTW the whole point of this project was to find something useful to do for one of my many plugpack type PSU's from obsolete equipment ( I have a whole box of them! )
spec
